Dynamic Icon/Color in Mushroom Chips Card Based on Sensor Value
Hey everyone,
I’m trying to configure the mushroom-chips-card to dynamically change the icon and icon color based on the value of a sensor, but I’m having some trouble getting it to work properly.
The idea is to have the icon and color change based on the battery level sensor, but with this config, the icon isn’t showing up at all. I’d like to achieve this directly in the card config without creating a separate sensor if possible.
CleanShot 2024-05-10 at 20.53.10@2x
Here’s the code snippet I’m using:
- type: entity
  entity: sensor.iphone_de_martin_battery_level
  icon: >-
    {% if states('sensor.iphone_de_martin_battery_level')|int > 80 %}
      mdi:battery
    {% elif states('sensor.iphone_de_martin_battery_level')|int > 50 %}
      mdi:battery-70
    {% elif states('sensor.iphone_de_martin_battery_level')|int > 20 %}
      mdi:battery-30
    {% else %}
      mdi:battery-alert
    {% endif %}
  icon_color: >-
    {% if states('sensor.iphone_de_martin_battery_level')|int > 99 %}
      green
      black
    {% elif states('sensor.iphone_de_martin_battery_level')|int > 30 %}
      orange
      red
    {% else %}
      black
    {% endif %}
Any ideas on what I’m doing wrong or how to fix this?
Thanks in advance for your help!
Hello, more informations in this guide=> Mushroom Cards Card Mod Styling/Config Guide - #3 by dimitri.landerloos
you can’t use templates in an entity card.
if you post the full code for the card you posted we can help you further.
  type: custom:mushroom-template-card
  icon: >-
    {% set battery = states('sensor.simonsphone_battery_level') |
    int %}
    {% if battery < 30 %}
      mdi:battery-30
    {% elif battery < 50 %}
      mdi:battery-50
    {% elif battery < 70 %}
      mdi:battery-70
    {% else %}
      mdi:battery
    {% endif %}
  icon_color: >-
    int %}
    {% if battery < 35 %}
      red
      orange
      yellow
    {% else %}
      green
    {% endif %}
I should have been clearer sorry, you can use templates in an entity card if you use card_mod.
like this example from @LiQuid_cOOled
type: custom:mushroom-entity-card
entity: light.bed_lights
card_mod:
  style: |
    ha-state-icon {
      --card-mod-icon: {{ 'mdi:mushroom;' if is_state(config.entity, 'on') else 'mdi:home' }}
Hi @Frosty, thank you for your help. Here is the full code for the card:
type: horizontal-stack
cards:
  - type: custom:vertical-stack-in-card
    cards:
      - type: custom:mushroom-person-card
        entity: person.martin
        icon_type: entity-picture
        primary_info: state
        secondary_info: last-updated
        card_mod:
          style: |
            ha-card {
              border: none;
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            icon: >-
                mdi:battery
                mdi:battery-70
                mdi:battery-30
              {% else %}
                mdi:battery-alert
              {% endif %}
            icon_color: >-
                green
                black
                orange
                red
              {% else %}
                black
              {% endif %}
          - type: conditional
            conditions:
              - entity: person.martin
                state: away
            chip:
              type: entity
              entity: sensor.maison_direction_du_deplacement_de_martin
              icon_color: purple
              icon: mdi:map-legend
              card_mod:
                style: |
                  ha-card {
                    border: none;
            alignment: left
    cards:
        entity: person.celine
        primary_info: state
        chips:
          - type: conditional
            conditions:
              - entity: sensor.iphone_de_celine_battery_level
                condition: numeric_state
                below: 20
            chip:
              type: entity
              icon: mdi:battery-low
              icon_color: red
              card_mod:
                style: |
                  ha-card {
                    border: none
          - type: conditional
            conditions:
              - entity: person.celine
                state: away
            chip:
              type: entity
              entity: sensor.maison_direction_du_deplacement_de_celine
              icon_color: purple
              card_mod:
                style: |
                  ha-card {
                    border: none;
            alignment: left
Of course, the goal is to have the same behavior for Martin and Céline.
TBH, my initial intention was to only show the battery level when it’s below 20% (as I did on Celine’s card). It works great, but the problem is that my card is cropped when no condition is met (i.e., my battery level is above 20%, and I’m at home).
Since that wasn’t working as intended, I thought of this solution to always display the battery level but with different icons and colors to add some visual interest.
OK can you try this.
sorry I only have my phone so it was hard to see what was going on, but it looks like you have the battery lvl nested inside a conditional card set for below 20% which would mean you wouldn’t see the icon and color change above 20%
ive just changed it to 100 for now and we can go from there.
cards:
    entity: person.simon_benson
    primary_info: state
    chips:
      - type: conditional
        conditions:
          - entity: sensor.simonsphone_battery_level
            below: 100
        chip:
          type: template
          content: >-
            {{states('sensor.simonsphone_battery_level')}}%
          icon: >-
            {% set battery = states('sensor.simonsphone_battery_level') | int %}
              mdi:battery-30
              mdi:battery-50
              mdi:battery-70
            {% else %}
              mdi:battery
            {% endif %}
          icon_color: >-
              red
              orange
              yellow
            {% else %}
              green
            {% endif %}
          card_mod:
            style: |
              ha-card {
                border: none
      - type: conditional
        conditions:
          - entity: person.simon_benson
            state: away
        chip:
          type: entity
          entity: sensor.home_simonsphone_direction_of_travel
          icon_color: purple
          card_mod:
            style: |
              ha-card {
                border: none;
        alignment: left
you can edit the {% elif battery < 70 %} to add more steps if you need to but you get the picture :blush:
It works like a charm! Thank you @Frosty! :pray:t2:
Do you have an idea about this ?
oh so you only wanted to show the battery <20 when your home.
not sure on that one. hopefully someone else can help you with that problem
