Dynamic icon on template select
I’m trying to update the icon dynamically on an template type select entity as described in the documentation (Template - Home Assistant) however the icon never changes:
Here is the template cote:
select:
  - name: "Radiateur Bureau"
    unique_id: radiateur_bureau_mode
    state: >
        {% set pilote = states('switch.radiateur_bureau_switch_pilote') %}
        {% set normal = states('switch.radiateur_bureau_switch_normal') %}
        {% if pilote == 'off' and normal == 'off' %}
          Confort
        {% elif pilote == 'on' and normal == 'on' %}
          Eco
        {% elif pilote == 'on' and normal == 'off' %}
          Arrêt
        {% endif %}
    icon: >
        {% if is_state("select.radiateur_bureau", "Confort") %}
          mdi-radiator
        {% elif is_state("select.radiateur_bureau", "Eco") %}
          mdi-radiator-disabled
        {% else %}
          mdi-radiator-off
        {% endif %}
    options: "{{ ['Eco', 'Confort', 'Arrêt'] }}"
    select_option:
      - service: script.radiateur
          mode: "{{ option }}"
          radiateur: "switch.radiateur_bureau_switch"
Everything else in the template is Ok. The script is correctly called etc… Just nothing happens on the icon. Does anybody see what is wrong here ?
use mdi:radiator
It definitely was that simple !
Thanks !
