dbrunt
(Daniel)
January 18, 2022, 10:10am
1
Finally have this working the way I had envisioned and hoped I could!
I am using Waze but that is somewhat beside the fact.
I tried all sorts of ways and means but this is the final working result which seems simple now!
First I created a new drop-down helper input_select.destination
and preset it with Home
Second is an automation to update the list based on Zones’ friendly names, and triggered by a state change in zones:
alias: Update Destinations
description: ''
- platform: event
event_type: state_changed
condition:
- condition: template
value_template: '{{ trigger.event.data.new_state.domain == "zone" }}'
- service: input_select.set_options
entity_id: input_select.destination
options: |
{%- set ns = namespace(items=[]) -%}
{% for entity in states.zone -%}
{%- set ns.items = ns.items + [entity.name | trim(",")] -%}
{%- endfor %}
{{ ns.items }}
mode: parallel
max: 25
The other part is a Waze selectable sensor destination:
- name: Destination address
unique_id: dest_address
state: "{{ states('input_select.destination') }}"
select:
- name: Select Destination
unique_id: select_destination
options: "{{ state_attr('input_select.destination','options') }}"
select_option:
service: input_select.select_option
option: "{{ option }}"
petro
(Petro)
January 18, 2022, 1:25pm
2
why do you have a trim there? There shouldn’t be a comma at the end of any zone name.
{{ states.zone | map(attribute='name') | list }}
EDIT: I’d also probably change the trigger, but that’s just me. You can change it to occur on home assistant restart, zone reloading, and automation reloading.
dbrunt
(Daniel)
January 18, 2022, 4:20pm
3
You’re right, the trim(",")
isn’t required. It was code I got from another thread. It was late and it worked so I didn’t test it further.
But how do I trigger on zone/automation reloading? I couldn’t find an answer to that…
petro
(Petro)
January 18, 2022, 4:28pm
4
- platform: event
event_type: call_service
event_data:
domain: zone
service: reload
dbrunt
(Daniel)
January 18, 2022, 9:22pm
5
This does not trigger the automation when I add/edit/delete Zones in HA.
Nor does it trigger if I execute an HA YAML configuration reloading of ZONES …
petro
(Petro)
January 19, 2022, 12:50pm
7
Then pare back the event_data to see all call_services that occur when you reload or add zones. I was making a guess on the trigger based on other reload services.
dbrunt
(Daniel)
January 19, 2022, 5:15pm
8
I watched call_service in Dev Tools and did not see anything when I edited a zone name…
I’ve been trying to figure out if I might be able to add something like trigger.event.data to reduce the trigger frequency but I am concerned that zone add/delete/edit just isn’t visible as a trigger since I cannot see anything in Listen to events . I’m also thinking now that my condition: {{ trigger.event.data.new_state.domain == “zone” }} isn’t catching what I want but something else and is actioning the input_select.set_options as a result.
description: ''
- platform: event
I have tried this but it doesn’t trigger:
- platform: event
event_data:
new_state:
domain: zone
condition: []
petro
(Petro)
January 19, 2022, 5:17pm
9
what does the state_changed event look like for zone?
dbrunt
(Daniel)
January 19, 2022, 6:26pm
10
I cannot see a state_changed for zone
yet the condition:{{ trigger.event.data.new_state.domain == "zone" }}
is executing the service: input_select.set_options
. I’ve been trying to spit out some data using service: notify.persistent_notification
. If I add a zone or edit a zone the automation executes but not if I delete a zone since there is no state change involved.
- platform: event
event_data: {}
condition:
options: |
{%- set ns.items = ns.items + [entity.name] -%}
{%- endfor %}
{{ ns.items }}
- service: notify.persistent_notification
title: '{{ trigger.event.data.new_state.domain }}'
message: '{{ trigger.event.data.new_state.entity_id }}'
The HA built-in events don’t cover an entity being deleted but I did find this while peeking and poking:
Event 1 fired 10:22 AM:
"event_type": "entity_registry_updated",
"data": {
"action": "remove",
"entity_id": "zone.test"
"origin": "LOCAL",
"time_fired": "2022-01-19T18:22:15.619767+00:00",
"context": {
"id": "5563eb5670053802675b7e33f3645d87",
"parent_id": null,
"user_id": null
Event 0 fired 10:20 AM:
"data": {
"action": "create",
"origin": "LOCAL",
"time_fired": "2022-01-19T18:20:52.276968+00:00",
"context": {
"id": "ebf39de40a23b5548a643b3c37412f84",
"parent_id": null,
"user_id": null
The registry is not updated when I edit a zone name though so I will need two triggers, one for state_changed where entity_id is in domain zone and another for entity_registry_updated where entity_id is in domain zone. Now to figure out the syntax for the triggers so they are limited to the zone domain…
petro
(Petro)
January 19, 2022, 6:34pm
11
You only need to update the zone list when things are created or deleted, so you have all the info you need.
description: ''
- platform: event
event_type: entity_registry_updated
condition:
value_template: "{{ trigger.event.data.action in ['create', 'delete'] and trigger.event.data.entity_id.startswith('zone.') }}"
options: "{{ states.zone | map(attribute='name') | list }}"
mode: parallel
max: 25
dbrunt
(Daniel)
January 19, 2022, 6:47pm
12
I hobbled this together:
- platform: event
event_data:
action: remove
- platform: event
event_data:
action: create
condition: []
options: |
{%- endfor %}
{{ ns.items }}
title: '{{ trigger.event.event_type }}'
message: '{{ trigger.event.data.action }} {{ trigger.event.data.entity_id }}'
which has two triggers and no condition but I like your trigger + condition better!
And thank you for this piece of tidy code!
I still need a state_changed trigger to cover when a zone name is edited…
petro
(Petro)
January 19, 2022, 6:52pm
13
That’s probably still a entity_registry_updated change. Personally I wouldn’t bother, how often are you changing zone names?
dbrunt
(Daniel)
January 19, 2022, 7:12pm
14
Not very often! I am looking more now to just conquering this!!
It did not trigger an entity_registry_updated
but I managed to find the state_changed this time through:
Event 20 fired 10:53 AM:
"event_type": "state_changed",
"data": {
"entity_id": "zone.select_express",
"old_state": {
"state": "zoning",
"attributes": {
"latitude": 49.23289236942634,
"longitude": -122.82306556407177,
"radius": 30.48013447922684,
"passive": false,
"editable": true,
"icon": "mdi:map-marker",
"friendly_name": "Select Express Courier"
"last_changed": "2022-01-19T14:03:08.927911+00:00",
"last_updated": "2022-01-19T18:51:37.039820+00:00",
"context": {
"id": "f5827c044eb772a94b1ece43e2ee7206",
"parent_id": null,
"user_id": null
"new_state": {
"state": "zoning",
"attributes": {
"passive": false,
"editable": true,
"friendly_name": "Select Express"
"last_updated": "2022-01-19T18:53:24.294448+00:00",
"context": {
"id": "66c7272b369176903756c4dd84ee3f3a",
"parent_id": null,
"user_id": null
Is there a way to define the trigger without a condition such that it only triggers on entity_id.startswith(‘zone.’)?
petro
(Petro)
January 19, 2022, 7:17pm
15
No, you trigger on everything and conditionally run the actions based on the event data. You can’t partially check data as a trigger.
dbrunt
(Daniel)
January 19, 2022, 7:34pm
16
Okay, thank you!
So now I have this
alias: Update Destinations (state_changed)
description: ''
- platform: event
event_data: {}
condition:
value_template: '{{ trigger.event.data.entity_id.startswith("zone.") }}'
options: |
{%- endfor %}
{{ ns.items }}
message: Edited {{ trigger.event.data.new_state.entity_id }}
and this
alias: Update Destinations (entity_registry_updated)
description: ''
- platform: event
event_data:
action: remove
- platform: event
event_data:
action: create
condition: []
options: |
{%- endfor %}
{{ ns.items }}
After an edit, a create new and then a delete I got 5 notifications
I disabled the (entity_registry_updated)
automation and did another edit, add, delete and got all three notifications via the (state_changed)
automation, and the input_select of course was updated.
Thanks for the assistance and knowledge!
please allow me to piggyback here, because I also had plans to add these zone creation deletion events to the dynamic input_select automation.
How come this works at all, because zones aren’t listed in the entity_registry? duh, ofc they are but only when created in the UI. I had all my zones in yaml…
btw I now use this template
{{expand(states.zone, states.person)|map(attribute='name')|list}}
which I find useful to be able to plan travels to my family
edited
made a user error before so edited the post.
btw2:
2022-01-20 11:17:58 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'str object' has no attribute 'data' when rendering 'Zones were update because of {{trigger.id}}. latest action:
- {{ trigger.event.data.action }} {{ trigger.event.data.entity_id }}'
2022-01-20 11:17:58 ERROR (MainThread) [homeassistant.components.automation.update_travel_options] Update travel options: Error executing script. Error for call_service at pos 2: Error rendering data template: UndefinedError: 'str object' has no attribute 'data'
2022-01-20 11:18:02 ERROR (MainThread) [homeassistant.components.automation.update_travel_options] Error while executing automation automation.update_travel_options: Error rendering data template: UndefinedError: 'str object' has no attribute 'data'
using:
- alias: Update travel options
id: Update travel options
mode: restart
max: 50
- platform: homeassistant
event: start
- platform: event
event_data:
action: create
- platform: event
event_data:
action: remove
condition:
condition: template
value_template: >
{{ (trigger.id in ['create','remove'] and
trigger.event.data.entity_id.startswith('zone.')) or
trigger.id == 'ha'}}
entity_id:
- input_select.destination
- input_select.origin
options: >
- service: system_log.write
message: >
latest action:
could this be the homassistant start event not having that data?
dbrunt
(Daniel)
January 20, 2022, 4:54pm
18
Yes, I discovered that last night and added the input.select update to my HA Startup automation:
alias: HA Startup
description: ''
event: start
condition: []
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: python_script.domains_in_use
- service: python_script.entities_in_use
- service: input_boolean.turn_off
entity_id: input_boolean.reset_multisensor
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: notify.alexa_media_last_called
message: Home Assistant has started
title: Home Assistant
type: tts
- choose:
- conditions:
- condition: device
type: is_off
device_id: f177253ec75b1464a93bef4e329770ac
entity_id: switch.plug_1
domain: switch
sequence:
- type: turn_on
domain: switch
- conditions:
- condition: device
type: is_off
entity_id: switch.plug_2
domain: switch
sequence:
- type: turn_on
domain: switch
- conditions:
- condition: device
type: is_off
entity_id: switch.plug_3
domain: switch
sequence:
- type: turn_on
domain: switch
default: []
mode: single
dbrunt
(Daniel)
January 20, 2022, 5:07pm
19
This should be action: 'delete'
- platform: event
event_data:
action: remove
So this…
Mariusthvdb:
event: start
- platform: event
event_data:
action: create
- platform: event
event_data:
action: remove
condition:
condition: template
value_template: >
can then be
- platform: event
condition:
or
- platform: event
event_data:
action: create
- platform: event
event_data:
action: delete
condition:
condition: template
value_template: "{{ trigger.event.data.entity_id.startswith('zone.') }}"
no:
"data": {
"action": "remove",
"entity_id": "zone.buurt"
"origin": "LOCAL",
"time_fired": "2022-01-20T19:03:35.551667+00:00",
it’s really ‘remove’
as is in my log:
2022-01-20 20:03:35 WARNING (MainThread) [ZONE EDITOR] Zones were updated because of 'remove'. latest action: entity_registry_updated
- remove zone.buurt
Ive ended up with:
mode: restart
max: 50
event: start
- platform: event
event_data:
action: create
- platform: event
event_data:
action: remove
condition:
condition: template
value_template: >
entity_id:
options: >
value_template: >
{{trigger.platform != 'homeassistant'}}
message: >
{{trigger.event.event_type|replace('_',' ')|capitalize}}
Zones were updated because of '{{trigger.id}}'.
latest action:
- {{trigger.event.data.action}} {{trigger.event.data.entity_id}}
level: warning
logger: ZONE EDITOR
and filter out the startup event for the logging.
dbrunt
(Daniel)
January 20, 2022, 7:25pm
21
Mariusthvdb:
You’re right!
Event 1 fired 11:23 AM:
"data": {
"action": "remove",
"origin": "LOCAL",
"time_fired": "2022-01-20T19:23:15.602323+00:00",
"context": {
"id": "d5de7fbf52ec61dc889258be85b01aba",
"parent_id": null,
"user_id": null
