I love picture-elements and have used it to show a clickable image to control devices. Now I’ve created a group element that lets you create dynamic UIs for much smarter use of screen real-estate.
New version - 0.3 with even more capabilities
Using the element
There are many possibe usages to the group element (samples follow below)
- Build a cleaner user interface by showing relevant controls only when a hot spot is tapped. For example: tap your cover/blinds and show the controls; tap your dimmer and show its controls;
No more clogged UIs or living without full control due to space contraints. - Easier positioining - all group children elements position and size are based on % of the group element itself. So if you have a certain element or a set of elements that you reuse you can position them once relative to each other and then move the entire group.
- Build a dynamic UI - for example a universal remote control (TV/Receiver/STB) taking up very little space. You can combine group-element with group-toggle-button (coming soon).
- Eliminates the need to define input_boolean entities just to toggle visibility of UI items. Also gives you freedom to use the interactive interface by multiple users without conflicts of a shared input_boolean entity.
Element options
| Name | Type | Default | Since | Description |
| type | string | required | v0.1 | custom:group-element |
| elements | list | required | v0.1 | Elements contained in the group. Any valid element hierarchy of picture-elements. |
| toggle_tap | boolean | false | v0.1 | Enable toggling visibility of children elements when tapped. |
| toggle_area_elements | list | v0.3 | Elements to be shown within the group container even if elements_pos is defined (and so the elements under elements will render there). |
| visible | boolean | true | v0.1 | Sets initial visibility. |
| visible_style | list | v0.3 | Styles to apply when group is visible (applied with !important). | |
| grouping_code | numeric | -1 | v0.1 | When using multiple group-elements this allows to specify that only a single group with the same grouping code should be shown. All other groups sharing the same grouping_code are automatically hidden. (only works within the same level) |
| no_toggle_hide | boolean | false | v0.3 | Should the group only toggle to visible when clicked and not toggle to hide if clicked again. Useful for us with grouping_code when grouping will hide the other groups anyway. |
| fully_hide_other_groups_on_show | boolean | false | v0.3 | Fully hides all other groups sharing the same grouping_code when this group is shown. This includes also the elements under the toggle_area_elements if specified. |
Elements position options (elements_pos)
If you want to separate the toggle area from the area that hosts the elements, use this object to set the position for the elements.
Note: All coordinates in this object are relative to the group parent and not to the group.
| left/right | string | v0.1 | Sets the left/right position of the element container. | |
| top | string | v0.1 | Sets the top position of the element container. | |
| width | string | v0.1 | Sets the width position of the element container. | |
| height | string | Sets the height position of the element container. | ||
| any other style | string | v0.1 | Sets additional style properties on the element container. |
Close_button object (close_button)
Optional button that hides the group on click in addition to tapping the group itself if toggle_tap is on
| show | boolean | false | v0.1 | Show the close button to enable closing the group (regardless of toggle_tap). |
| icon | string | hass:close | v0.1 | Sets the icon to show on the close button. |
Style object (style)
Optional styles for the close button
You should position (and otherwise manipulate) the close button
| left/right | string | v0.1 | Sets the left position of the close button (CSS). | |
| top | string | v0.1 | Sets the top position of the close button (CSS). | |
| any other style | string | v0.1 | Sets additional style properties on the close button. |
Example usage
Basic setup
Group controls in a group that is initially hidden and shows when tapped. All elements are within the group.
- type: picture-elements
image: /local/living-room.jpg
elements:
type: 'custom:group-element'
toggle_tap: true
visible: false
style:
height: 40%
left: 67%
top: 30%
width: 25%
- elements:
# your elements go here - their size/position is relative to the group
Elements shown outside of hot spot (toggle area)
To show elements outside of the group area use the elements_pos object. This allows you to define a hot spot (in the group’s location) separate to the elements shown when the hot spot is tapped.
elements:
- type: 'custom:group-element'
visible: false
toggle_tap: true
style:
# the group style determines the hotspot
height: 40%
left: 41%
top: 30%
width: 25%
elements:
elements_pos:
# the elements_pos style determine the location of the elements
left: 10%
top: 65%
width: 80%
height: 30%
transform: none
background-color: 'rgba(255, 255, 255, 0.6)'
border-radius: 10px
Close button
You can hide the group by clicking a close button you can add and position
elements:
visible: false
toggle_tap: true
style:
height: 40%
left: 41%
top: 30%
width: 25%
elements:
elements_pos:
left: 10%
top: 65%
width: 80%
height: 30%
transform: none
border-radius: 10px
close_button:
# the close button determines the location of the close button
show: true
style:
border-color: black
border-radius: 10px
border-style: solid
left: 1%
top: 69%
transform: none
Grouping
When you have multiple groups (group-element) that may reuse the same real estate it makes sense for one of them to hide all others when it is visible.
To do this, set the grouping_code to the same number on all groups that should share the real estate.
elements:
# first group - with grouping_code of 1
visible: false
toggle_tap: true
grouping_code: 1
style:
height: 40%
left: 41%
top: 30%
width: 25%
elements:
elements_pos:
left: 10%
top: 65%
width: 80%
height: 30%
transform: none
border-radius: 10px
close_button:
show: true
style:
border-color: black
border-radius: 10px
border-style: solid
left: 1%
top: 69%
transform: none
# second group - also with grouping_code of 1
# second group's element_pos & close_button is identical to group 1 and they share the
# same real-estate so they need to not be shown together
visible: false
toggle_tap: true
grouping_code: 1
style:
height: 40%
left: 68%
top: 30%
width: 25%
elements:
elements_pos:
left: 10%
top: 65%
width: 80%
height: 30%
transform: none
border-radius: 10px
close_button:
show: true
style:
border-color: black
border-radius: 10px
border-style: solid
left: 1%
top: 69%
transform: none
Installation - go to https://github.com/custom-cards/group-element
