Chacsam
(Frédéric)
March 13, 2023, 10:29am
1
Hi
I have a challenge with a plex service.
When in /developer-tools/service, my code works perfectly:
service: media_player.play_media
media_content_type: PLAYLIST
media_content_id: "plex://{"playlist_name":"{{states('sensor.template_selected_plex_playlist_uuid')}}","shuffle":"1"}"
entity_id: {{states('sensor.template_selected_media_music_device')}}
When I copy/paste this code into a (conditional) script, it doesn’t work anymore, it gives
Message malformed: Service does not match format <domain>.<name> for dictionary value @ data['sequence'][2]['choose'][1]['sequence'][1]['service']
The full script:
alias: Media - Music Play
sequence:
- service: media_player.media_stop
data: {}
entity_id: "{{ states('sensor.template_selected_media_music_device') }}"
- choose:
- conditions:
- condition: state
entity_id: input_select.media_music_source
state: Plex
sequence:
- service: media_player.play_media
- conditions:
- condition: state
state: Radio Web
sequence:
media_content_id: >-
media-source://radio_browser/{{
states('sensor.template_selected_webradio_uuid') }}
media_content_type: audio/aac
mode: single
icon: mdi:music-circle-outline
Any clue?
petro
(Petro)
March 13, 2023, 10:49am
2
You’re missing quotes for target’s entity_id around your template and your quoting is wrong for media_content_id. If you want to avoid quoting, use multiline yaml notation.
media_content_id: >
entity_id: >
the rules of quoting are simple, but often overlooked. You can’t have the same inside quotes as outside quotes. So if you use " inside, you have to use ’ outside and vice versa. Also, if your value starts with a letter, it’s assumed to be a string and you don’t need quotes.
Meaning the following would have worked for media_content_id:
media_content_id: plex://{"playlist_name":"{{states('sensor.template_selected_plex_playlist_uuid')}}","shuffle":"1"}
or
media_content_id: 'plex://{"playlist_name":"{{states("sensor.template_selected_plex_playlist_uuid")}}","shuffle":"1"}'
and the following would have worked for entity_id:
entity_id: "{{states('sensor.template_selected_media_music_device')}}"
or
entity_id: '{{states("sensor.template_selected_media_music_device")}}'
Good day, can you share your “sensor.template_selected_plex_playlist_uuid” and “sensor.template_selected_media_music_device” yaml?
thank you
Chacsam
(Frédéric)
April 9, 2023, 3:51pm
5
Those are just variables I fill in based on a input_select field.
eg, for devices, I have an interface to select the target
input_select:
media_music_device:
name: Media - Music Hauts-Parleurs
options:
- Cuisine
- Rez-de-chaussée
- Maison entière
- Chambre Enfants
- Chambre Parents
- Salon
- Garage
icon: mdi:cast-audio
With a template converting it in the right format for my script.
template:
- sensor:
- unique_id: "selected_media_music_device"
icon: "mdi:cast-audio"
state: >-
{% if is_state("input_select.media_music_device", "Cuisine") %} media_player.paire_cuisine
{% elif is_state("input_select.media_music_device", "Rez-de-chaussée") %} media_player.rez_de_chaussee
{% elif is_state("input_select.media_music_device", "Maison entière") %} media_player.maison
{% elif is_state("input_select.media_music_device", "Chambre Enfants") %} media_player.chambre_enfants
{% elif is_state("input_select.media_music_device", "Chambre Parents") %} media_player.mini_parents
{% elif is_state("input_select.media_music_device", "Salon") %} media_player.paire_salon
{% elif is_state("input_select.media_music_device", "Garage") %} media_player.garage_audio
{% endif %}
attributes:
friendly_name: "Audio Media Player choisi"
filter_key: "Music_Player"
I am using a similar principle for the Plex playlist.
