Now that the Tesla Fleet integration has changed its polling interval to a static one, and suggests using an automation to emulate the previous dynamic polling, I wonder if anyone has already made a nice automation, or have some ideas on what factors to include when creating a dynamic approach.
Hello, I need a automation to open my Garage Door even when I open my Car!
Does anybody have any Idea?
It seems that obviosly function cannot be supported from the tesla app.
I have the following configuration
(Checked ON) …Force cars awake on startup !
Also I want to open my Garage Door if the location tracker (device_tracker.gerryteslam3_location_tracker) …triggered to be at “Home”.
But this also not working correct in case of delayes in sending / polling the data out of my Tesla to be received in hoemassistant.
longer duration every 4 hours - to be used in at home conditions
normal duration every 30 minutes - to be used in driving conditions but not very close to home and my phone is connected to the car
short duration every 15 seconds - to be used in driving conditions while my phone is 1 km close to home and while i am approaching to home and my phone is connected to the car
if the conditions of each respective triggers are satisfied, call update_entity service on home assistant for tesla integration.
Still not finalised properly, will keep you posted.
Keep in mind that each trigger has a specific id and i am using conditions to check if respective trigger’s conditions are satisfied before calling update entity service.
alias: "Tesla polling update "
description: ""
triggers:
- trigger: time_pattern
hours: /2
minutes: /10
seconds: /15
- trigger: homeassistant
event: start
conditions:
- condition: or
conditions:
- condition: and
conditions:
- condition: trigger
id:
- Longer
enabled: true
- condition: state
entity_id: device_tracker.model_3_location
state: home
- condition: and
conditions:
id:
- Normal
- condition: not
conditions:
- condition: state
state: home
- condition: and
conditions:
id:
- Shorter
- condition: state
entity_id: binary_sensor.fuat_connected_to_tesla
state: "on"
- condition: state
entity_id: device_tracker.fuat_mobile
state: not_home
- condition: numeric_state
entity_id: sensor.home_proximity_fuatx3pro_distance_2
below: 1000
- condition: state
entity_id: sensor.home_proximity_fuatx3pro_direction_of_travel_2
state: towards
id:
- Start
actions:
- choose:
- conditions:
id:
- Start
sequence:
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- action: homeassistant.update_entity
entity_id:
- device_tracker.model_3_location
mode: single
How did you go with this? I was using Teslametry which pulled regularly. But moved to Tesla fleet and trying to solve this. I am currently trying number plate recognition with frigate. No luck.
yeah i am now trying with teslsa fleet - if my car shows destimation less than 2km away - to poll home status of car every 5 seconds. then it stops after 10 mins
Ill see how this goes. I just like the free credit with tesla fleet. teslemetry can cost a bit
I am using both TeslaMate (MQTT to HA) and TeslaFleet (the official integration).
Both have their pros and cons.
Mostly, I use TeslaFleet to send commands to the car, and a combination of the sensors from Fleet and Mate for monitoring, alerting etc.
I have an automation that runs every minute, and will adjust the poll interval for TeslaFleet based on different sensors, both from TeslaFleet and TeslaMate.
If the car is actively charging, Poll Interval is set to 1 minute.
If the car is in Neutral, Drive or Reverse (e.g. not in Park), Poll Interval is set to 1 minute
This give me frequent (enough for me, at least) updates when the car is doing something interesting.
Energy usage is not that important, as the car is driving or chargin anyway, and the frequent polling does not add that much to it.
And this will usually keep me well below the included limit of poll requests without causing any high charges from using the API.
If the car is connected to a charger, but not actively charging, Poll Interval is set to 5 minutes.
This will ensure I get reasonably updated information about charging sessions, battery state etc. Energy usage is not that important, as the car is connected. And it allows for saving some poll requests when the car is not really doing anything.
If the car is Parked, and NOT connected to a charger, I set Poll Interval to 10 minutes.
This ensures that the car can sleep, and saves further API requests, while still ensuring that the data is not going stale.
Since I use both TeslaMate (MQTT) and TeslaFleet sensors, one or more of the relevant sensors will usually be updated as soon as the car wakes up when someone unlock it, so the Poll Interval change from 10 to 1 minute does usually not have to wait for the entire 10 minute interval to complete.
