i’m trying to make get an dynamic alert repeat time based on an input number. The alert is used to remind me to close a window if is open for the repeat time. The time should be dynamic based on the outside temperature. Setting the inputer_number dynamically works fine but i don’t know how to set the repeat time in the alert function to the input_number.
the following does not work
schlafzimmer_fenster:
name: "Schlafzimmer Fenster offen"
message: "Das Schlafzimmerfenster ist noch offen"
entity_id: binary_sensor.og_schlafzimmer_schiebetur_verschlussuberwachung
state: "on" # Optional, 'on' is the default value
repeat: input_number.schlafzimmer_fenster_alert
can_acknowledge: true # Optional, default is true
skip_first: true # Optional, false is the default
notifiers:
- telegramfah
i get this errot
Invalid config for [alert]: expected float @ data['alert']['schlafzimmer_fenster']['repeat'][0]. Got 'i'. (See /config/configuration.yaml, line 38).
any help is appreciated
