EDIT - I would format this error but the mobile front end doesn’t allow it any more
Anyone else seeing dynamic scenes which have worked for years (scene create service call) now doing this intermittently when asked to be activated …
Logger: homeassistant.components.automation.lights_red_on_error_off_or_on_choice
Source: helpers/script.py:468
Integration: Automation (documentation, issues)
First occurred: 18:45:45 (2 occurrences)
Last logged: 18:45:45
Lights Red on Error - Off or On Choice: Choose at step 1: default: Error executing script. Unexpected error for call_service at pos 2: unexpected end of data: line 1 column 827 (char 826)
Lights Red on Error - Off or On Choice: Error executing script. Unexpected error for choose at pos 1: unexpected end of data: line 1 column 827 (char 826)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 2035, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2072, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 904, in entity_service_call
task.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1219, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 948, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 114, in _async_activate
await self.async_activate(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 334, in async_activate
await async_reproduce_state(
File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 67, in async_reproduce_state
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 61, in worker
await platform.async_reproduce_states(
File "/usr/src/homeassistant/homeassistant/components/light/reproduce_state.py", line 193, in async_reproduce_states
File "/usr/src/homeassistant/homeassistant/components/light/reproduce_state.py", line 180, in _async_reproduce_state
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 876, in entity_service_call
response_data = await _handle_entity_call(
result = await task
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 580, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/wled/helpers.py", line 28, in handler
await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/wled/light.py", line 247, in async_turn_on
await self.coordinator.wled.segment(**data)
File "/usr/local/lib/python3.11/site-packages/wled/wled.py", line 515, in segment
await self.request("/json/state", method="POST", data=state)
File "/usr/local/lib/python3.11/site-packages/backoff/_async.py", line 151, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/wled/wled.py", line 211, in request
response_data = await response.json()
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 84, in json
return await super().json(*args, loads=loads, **kwargs)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 1120, in json
return loads(stripped.decode(encoding))
orjson.JSONDecodeError: unexpected end of data: line 1 column 827 (char 826)
