I want to run a script select_maintenance_task
to select an “asset” option in an input_select. It looks something like this obviously. My question relates to parameterising the option.
sequence:
- service: input_select.select_option
entity_id: input_select.maintenance_asset
option: "selected option"
The script is called via a call service from a card tap action as below.
tap_action:
action: call-service
service: script.select_maintenance_task
The card doesn’t know the “asset” in question so it can’t simply pass that as a variable which the script could then use (passing-variables-to-scripts).
It just knows it is either task 0, task 1 or task 2. It gets its label by looking that index up in the attributes of an entity called maintenance_tasks
which has attributes like below.
This way I can add several cards, each with a different index and their label dynamically generated. The attributes of maintenance_tasks
change, so this is all necessary.
task_0_asset: Outdoor Blinds
task_1_asset: Food Fridge
task_2_asset: Washing Machine
I need to pass the “asset” to the script. I experimented with using templates for the data
in the service call of the card tap_action but understand you cannot use templates here.
eg: this doesn't work
tap_action:
asset: {{ state_attr('var.maintenance_tasks', 'task_0_asset') }}
I’ve then looked at simply passing the index and getting the script to find the asset via lookup from the state attributes of maintenance_tasks
eg: this part works obviously
tap_action:
index: 0
…but then I hit snags in the script trying to lookup the attribute value. Below I show two failed attempts.
script:
select_maintenance_task:
fields:
index:
description: '0-based index of UI element corresponding to the upcoming task.'
example: 0
sequence:
entity_id: input_select.maintenance_assets
**this doesn't work...**
option: |
{% set attribute = 'task_' + {{ index }} + '_asset' %}
{{ state_attr('var.maintenance_tasks', attribute) }}"
**nor this...**
option: |
**or this...**
option: "{{ state_attr('var.maintenance_tasks', 'task_{{ index }}_tasl' ) }}"
Is there any way I can achieve this dynamic access of state?
