Dynamic value in progress bar not working
I’m trying to have this code for a custom:bar-card to work, as I want to have the max attribute be dynamic according to each file printed, so the progress bar reacts accordingly.
I’m aware that the card does not accept a string, but just a number so I though maybe I can circumvent the card restrictions with just a little template.
It does not work.
Is there a way to make this work?
entities:
  - entity: sensor.bambu_p1s_current_layer
    max: ${states["sensor.bambu_p1s_total_layer_count"].state}
type: custom:bar-card
Thank you in advance
This part seems to be taken from a “bar-card inside config-template-card” example. Find an origin of your code & try to reproduce it fully.
I understand that the feature I wanted was removed in Version 3.0 of the card (why? it was so simple, @Gluwc )
i had to use this code instead, I hope it will help someone in the future
type: custom:config-template-card
entities:
  - sensor.bambu_p1s_current_layer
  - sensor.bambu_p1s_total_layer_count
card:
  max: ${{states["sensor.bambu_p1s_total_layer_count"].state}}
