Dynamically accessing variables
I’d like to create a script that takes an arbitrary entity ID from the MQTT json payload and accesses the entities values. Here is an example. This example is specifically for the TP-Link HS110 switch but if possible I’d like to apply it to several values.
      - service: mqtt.publish
        data_template:
          topic: 'homeassistant/uplink'
          payload : "{{ states.switch[trigger.payload_json['plugID']]['attributes']['voltage'] | float}}"
This does not pass the check configuration, but replacing the payload line with
          payload : "{{ states.switch['exampleEntityID']]['attributes']['voltage'] | float}}"
does parse.
I’ve tried to create a similar sample in the dev-template test page, I’m hoping the following is accurately replicating whats happening in production (shown above)
{% set trigger = {
  "payload_json": {
  	"plugID" : "exampleEntityID"
{% set states = {
  "switch": { "exampleEntityID" : {"attributes": {"voltage" : 120.1 }} }
{{ trigger.payload_json['plugID'] }}
{{ states.switch['exampleEntityID']['attributes']['voltage'] | float}}
outputs
exampleEntityID
120.1
120.1
What syntax am I doing incorrectly? Is there a web page I read up on and check the syntax? I’m guessing this has something to do with the Jinja scripting but I’m unable to find a good example of what I want. Some mention using the format command like so
payload : "{{ states.switch['s' | format(trigger.payload_json['plugID'])]['attributes']['voltage'] | float}}"
That gives mixed/incorrect results.
For anyone looking for a solution, I was able to get something going by changing around ’ and "
payload : '{{ states.switch["%s" | format(trigger.payload_json["plugID"])]["attributes"]["voltage"] | float}}'
If anyone thinks there is a better way to accomplish this I am open to suggestions.
Hmm. I’m not seeing why your original try doesn’t pass the configuration check. But maybe try something like this:
        data_template:
          payload : "{{ state_attr('switch.' ~ trigger.payload_json.plugID, 'voltage') | float }}"
