Hello and happy new year to everyone.
I have two picture entity cards acting as triggers for an automation that turns my water heater on, each for different time periods. The ‘shower’ option for 10 minutes and the ‘bath’ option for 20.
These two should be mutually exclusive. Ideally when I turn one on, the other should be grayed out (its tap_action disabled). Is this possible somehow?
With the ‘shower’ state on, I shouldn’t be able to interact with the bath card, they should never both be active at the same time:
I don’t want to hide the second card completely with a conditional. I believe custom components that ‘lock’ elements or cards don’t work dynamically either.
I’ve only found this semi-relevant reddit discussion, where someone mentions groups as a solution. But groups would only work(?) for single entities and not whole lovelace cards, correct?
This is my code, I’m toggling input_booleans and the automation catches the state change. I’ve tried using [state of shower = ‘on’] as a condition to block the bath automation but it’s not working.
type: horizontal-stack
cards:
- type: picture-entity
entity: input_boolean.water_shower_now
tap_action:
action: toggle
entity: input_boolean.water_bath_now
tap_action:
action: toggle
