Dynamically setting delays and transitions
Hi all.
I am making an esphome based, motion sensor driven RGB light.
I managed to have the basic behavior working, but now I am trying to get the different durations (fade-in, stay on and fade-out) settable by potentiometers.
I tried using lambdas to drive the transition_length and delayed_off parameters but they are not templatable.
It seems something that would be quite common, but my searches and experiments could not bring anything.
Any tip on how to proceed ?
My current yaml for reference:
light:
  - platform: rgb
    red: red_component
    green: green_component
    blue: blue_component
binary_sensor:
  - platform: gpio
    pin: 27
    device_class: motion
    on_press:
      then:
        - light.turn_on:
            transition_length: 3s
    name: "Movement Sensor Delayed"
    lambda: |-
      return id(movement).state;
    filters:
      - delayed_off: 60s
    on_release:
      then:
        - light.turn_off:
            transition_length: 30s
output:
  - platform: ledc
    pin: 18
  - platform: ledc
    pin: 13
  - platform: ledc
    pin: 26
From the specs:
  • transition_length (Optional, Time, templatable): The length of the transition if the light supports it.
Perhaps you should post some code of your template code you tried with.
Have a look at the examplecode at
in the section on_json_message Trigger … which does use lamba with transition_length
Thank you, I was trying too hard.
I was trying to do it like this:
            transition_length:
              seconds: !lambda |-
                return 3;
But it works without the seconds:, just with:
            transition_length: !lambda |-
              return 3000;
Any way to do it with delayed_off or to achieve an effect similar to it ?
When I try this:
      - delayed_off:  !lambda |-
          return 30000;
I get this error:
  filters:
      This option is not templatable!.
        return 30;
@justone pointed me in the right direction for transition_length.
For delayed_off, there is no direct way to do this. But it can be achieved with a script and a delay step.
Here is the approach to take for anyone passing here:
script:
  - id: light_cycle
    mode: restart
    then:
      - light.turn_on:
            return id(on_duration).state;
      - delay: !lambda |-
          return id(stay_duration).state;
      - light.turn_off:
            return id(off_duration).state;
binary_sensor:
  - platform: gpio
    name: ${disp_name} Presence Sensor
    pin:
      number: GPIO27
      mode: INPUT_PULLDOWN
    on_press:
      then:
        - light.turn_on:
            red: 1.0
            green: 0.2
            blue: 0.1
    on_release:
      then:
        - light.turn_on:
            transition_length: 5s
            red: 0.0
            green: 1.0
            blue: 0.0
        - delay: 3s
        - light.turn_off:
    filters:
      - delayed_on: 10ms
      - delayed_off: 2s
