I am trying to create some scripts to control my Dyson AC, I have been able to configure heating but not been able to get the device into AC ('Cooling Mode").
Has anyone had any luck getting the device into AC mode?
I have also found I have to put in some delays to my script otherwise the script doesnt work, I am guessing this is a timing issue? Anyone else encountered this?
Sorry but this is not related to your post - but I want something of the same.
But I saw, that you previously had trouble with Home Assitant not finding your Dyson.
I have created an account on both website and the app, with the device linked, but I can’t be added in HA…
I have 2 devices a HP03 and HP04, My 04 is not found in my account but my 03 connects fine.
Since my 03 is connecting I am currently configuration and adding automations. I believe the 04 has an issue but I’ll keep you informed if I make any progress.
Well, the “AC Mode” of the Dyson is just the FAN Mode. It will not actively cool down your place. Therefore, also no temperature set. Just turn it on without heating mode and you should be set
@AlmostSerious thanks the HP03 has hot cold, I acknowledge it’s not normal cooling but it’s a little better than just a fan. From memory just turning it on does not activate “cooling” mode but I will check this and confirm.
Today I have solved this, I used ‘climate.set_hvac_mode’. Please see my code below note I have some delays in my code as i found this works more smoothly but need to do some more testing to see what is really required.
I also have a smart switch which I turn off/on as you will see in the scripts I call.
