Does anyone know if the PH01 is supported?
I have tried to configure with my username, password, serial number & IP address but no luck?
Any suggestion to get this device to work?
Thanks,
Oliver
Thanks,
Oliver
No success, Unfortunately. If you have any ideas please share.
Hurra! It works in native integration on my Home Assistant version 0.114.1
I am getting the follow errors but I have confirmed my username, password and location are correct in the /config/configuration.yaml file. Any suggestions?
Success but not sure exactly how. I did remove the device ID and used the auto discovery. I also used the Configuration Validation in the Server controls to check the file was fine. Now it works for both my Dyson Fans.
Tried to set up my PH01 as of today - same failure. Mind of of you sharing his anonymised config entry?
Thanks in advance.
