In the logs I can see that the dyson is found:
020-01-06 17:54:02 DEBUG (SyncWorker_16) [homeassistant.components.dyson] Starting sensor/fan components
2020-01-06 17:54:02 DEBUG (SyncWorker_11) [homeassistant.components.dyson.fan] Creating new Dyson fans
2020-01-06 17:54:02 DEBUG (SyncWorker_17) [homeassistant.components.dyson.vacuum] Creating new Dyson 360 Eye robot vacuum
2020-01-06 17:54:32 DEBUG (Thread-2) [homeassistant.components.dyson.air_quality] air_quality: Message received for Salon device: DysonEnvironmentalSensorV2State(temperature=298.8,humidity=57,particulate_matter_25=6,particulate_matter_10=3,volatile_organic_compounds=4,nitrogen_dioxide=6,p25r=7,p10r=6,sleep_timer=0)
2020-01-06 17:54:32 DEBUG (Thread-2) [homeassistant.components.dyson.sensor] Message received for Salon Humidity device:
The questions I have:
I can’t see the Dyson integration in the integration tab
I can’t see the Dyson device in the devices tab
No automatic cards have been generated in the UI
When I try to add a sensor card, i can’t see the air_quality entity. I see however temperature and humidity
I think 1 and 2 are normal: I have a pure hot+cool link and also don’t see dyson there.
WIth my de vice I get some sensors for AQI and dust (unclear if these are from the actual device, or just from the dyson cloud, which also does predictions about air quality outside - anybody knows?), but no air_quality entries - but that may be because it isn’t supported (yet?) on the device, as the manual states, somwahet ambiguously:
Air Quality
The dyson air quality platform provides the following levels:
Note: currently only the 2018 dyson fans are supported(TP04 and DP04).
Supported fan devices
Pure Cool link (desk and tower)
Pure Hot+cool link (see climate part) for thermal control
Pure Cool 2018 Models (TP04 and DP04)
I think mine is from 2018, so supported (or not considered a “fan” here?) - but then again the part “for thermal control” seems to imply only that part should work?
Here is my Dyson Config that i use right now. I havent had the time to get the rest working, i need to check more threads on how to control it.
Configuration.yaml
# Dyson Config
dyson:
username: !secret dyson_user <---- Replace with username
password: !secret dyson_pw <---- Replace with password
language: FR <---- Replace with the language on your account
devices:
- device_id: VS5-CA-XXXXX <---- Replace with your Dyson Appliance Serial Number
device_ip: 192.168.5.2 <---- Replace with your Dyson Appliance IP
