Earthbound
A custom theme for Home Assistant based on the game Earthbound
Note: This is a very early work in progres but it seems to work pretty well.
Screenshots
Main
HACS installation - recommended
- Open HACS
- Select "Frontend"
- Select the ... menu button at the top right
- Select "Custom repositories"
- At the bottom left of the menu where it says "Add custom repository URL" add this repository: GitHub - JOHLC/Earthbound: A custom theme for Home Assistant based on the game Earthbound · GitHub
- Select the "Theme" category
- Select "ADD"
- Close this menu
- "Transparent Blue" should now show up as a new repository
- Click "INSTALL" then install again on the pop-up
Manual Installation - not recommended
- Download the earthbound.yaml file from the latest release
- Upload the downloaded file to your "themes" directory
- Add the resource reference to your lovelace config
You should now be able to select this theme in Home Assistant
