Hi, I have an Easee Charger and an Easee Equalizer, and I’m experiencing issues with controlling the charging limitations. Occasionally, I get a “Limited by equalizer” message, but I can’t figure out what’s causing this limitation.
It seems that the equalizer_limit
is the value setting the restriction. However, when I try to change it, it reverts back to its original value.
Here are my current settings:
Charger:
- max_circuit_limit: 16 A
- max_charger_limit: 16 A
- offline_circuit_limit: 16 A
- dynamic_circuit_limit: 16 A
- dynamic_charger_limit: 32 A
Equalizer:
- equalizer_limit: 10 A (as of now)
At the moment, the total household consumption is 10.7 kW (approximately 19.6 A), and the car is charging at 6.7 kW (9.8 A).
Could you help me understand what determines the equalizer_limit
and why it keeps resetting?
