Hi everybody,
we have manual roller blinds on our windows (so not even “dumb, but electrically controlled” ones). Example pictures, not from our home:
So basically:
- blinds are installed outside
- belt take-up reel installed inside
- nothing motorized
- no electricity near the installation
We live in a two story house and the first roller blinds I would like to automate are the ones for the upstairs master bed room, so retrofitting a motor inside the case (which is installed on the outside of the house), such as the one below, might be difficult both due to the hight and the fact that I never dealt with this before.
I did some research and found so called “elektrische Gurtwickler” (= “electric belt take-up reels”). These can be installed in place of the manual reels we currently use. The are plugged into a regular outlet, which kinda sucks, but for now is better than running additional wire in our brick walls.
However! These all seem to need a hub, for example the Rademacher Start2Smart Bridge
. That would be ~€76 or or the least expensice bridge, then ~€150 per reel. Or ~€460 for the more powerful bridge and two reels included. Pretty pricey!
Currently, we have an Ikea FYRTUR
zigbee cover, which works, but
- is installed on the inside. So there are the regular blinds on the outside and now the Ikea thing on the inside
- works well for blocking light, but the outdoor blinds would work much better in summer to also block heat
Then there’s the cheapest, but imho most difficult solution: install blind motors inside each outside blind case, run the wires, and connect a Shelly
(or perhaps even an ESPHome
??). This would require running electrical wire, then replastering and repainting the walls, and figuring out how to even install the blind motors in the first place. Once that’d be done, it’d be my favorite solution, as there is no third party bridge and everything could run locally. But it is a lot of work which I might be able to do, but don’t have any experience in. And it’ll probably be very difficult on the second floor.
Do any of you know of WiFi controlled (local API or similar, no cloud) belt tale-up reels, or ones that run on zigbee2mqtt, or last resort, even zwave, that would allow me to keep the installation as is and just replace the indoors reels with motorized ones, yet not require a third party hub or bridge?
While the ikea fyrtur thing is nice, it is also pretty pricey (~€150 plus €39 shipping because why not) and the main disadvantage I see is that the are on the inside. Being able to control my regular blinds (that are on the outside) also add a layer of security when lowering them at night and/or when not home. They are no real protection, but breaking in would be louder and take more time with those in front of the windows.
Thank you for any suggestion you might have
