If you want an easy way to add multiple sensors to Home Assistant, check out SensorNode:
https://tnbtechnologies.com/sensornode
<1 min up and running - no code - no hassle!
how is SensorNode integrated to Home Assistant?
Web site looks like it is still under construction.
Any section can’t expand.
Menu works ok for me.
Where is the source for this open source product?
Hi there,
SensorNode uses 2.4 GHz WiFi to talk to Home Assistant. I uses the HA ‘HTTP Sensor’ API.
Hope that helps.
Tom
Sorry perhaps I was working on it when you went there? Could you try again - be specific - are you talking about the sections labeled “Key Features of Every SensorNode” on the sensornode page?
Thanks for letting me know.
Tom
The plan is as soon as I launch my Kickstarter, after successful funding, I’ll release the code to all backers and then open-source to everyone shortly thereafter. I plan to launch the Kickstarter by the end of 2024.
Thanks.
Tom
Sorry, web site works fine. It was my add blocker. Somehow it prevents sections to expand, maybe it blocked some javascript. Sorry again.
no worries.
Thanks for sharing!
