clarky860
(Alistair Clark)
March 11, 2024, 2:14pm
1
Hi all,
I’m trying to get my SDM230 Modbus to work with ESPhome and have followed the guide here
But I am struggling to get it to work.
here is my config:
esphome:
friendly_name: Solar Power
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "********************************************"
ota:
password: "********************************"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Solar-Power Fallback Hotspot"
password: "************"
captive_portal:
uart:
rx_pin: D1
tx_pin: D2
baud_rate: 9600
stop_bits: 1
- platform: sdm_meter
phase_a:
current:
voltage:
active_power:
power_factor:
name: "SDM230M Power Factor"
apparent_power:
name: "SDM230M Apparent Power"
reactive_power:
name: "SDM230M Reactive Power"
phase_angle:
name: "SDM230M Phase Angle"
frequency:
name: "SDM230M Frequency"
total_power:
name: "SDM230M Total Power"
import_active_energy:
name: "SDM230M Import Active Energy"
export_active_energy:
name: "SDM230M Export Active Energy"
import_reactive_energy:
name: "SDM230M Import Reactive Energy"
export_reactive_energy:
name: "SDM230M Export Reactive Energy"
update_interval: 60s
I have D1 to A+ and D2 to B-
the Baud rate is 9600 on both the esp device and the SDM230
clarky860
(Alistair Clark)
March 13, 2024, 2:06pm
2
I got it working today.
For anyone else finding this here is what I did:
I first ordered a TTL to RS485-485 to Serial UART Adapter.
I then switched to an ESP32 board (not that this matters)
When trying on the tx rx (GPIO1 and GPIO3) pins i just kept getting errors, finally I switched to pins 16 & 17 and for some reason it works
esphome:
esp32:
board: nodemcu-32s
framework:
type: arduino
version: 2.0.6
# Enable logging
logger:
baud_rate: 0
api:
encryption:
key: "*************************************"
ota:
password: "*****************************"
wifi:
ap:
password: "**********"
captive_portal:
switch:
- platform: restart
web_server:
port: 80
time:
- platform: homeassistant
#serial port
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
stop_bits: 1
modbus:
send_wait_time: 500ms
uart_id: mod_uart
modbus_controller:
- id: SDM230M
modbus_id: mod_bus
address: 1
setup_priority: -10
update_interval: 5s
# General
# - platform: modbus_controller
# modbus_controller_id: SDM230M
# name: ${friendly_name} AvgFreq
# register_type: read
# address: 0x0046
# value_type: FP32
# unit_of_measurement: Hz
# state_class: "measurement"
# accuracy_decimals: 3
# name: ${friendly_name} Total System Power
# address: 0x0034
# value_type: FP32
# unit_of_measurement: W
# device_class: "power"
name: ${friendly_name} Total Active Energy
register_type: read
address: 0x0156
value_type: FP32
unit_of_measurement: kWh
state_class: "total_increasing"
device_class: "energy"
# name: ${friendly_name} Average Line to Neutral Voltage
# address: 0x002A
# value_type: FP32
# unit_of_measurement: V
# device_class: "voltage"
# name: ${friendly_name} Average Line Current
# address: 0x002E
# value_type: FP32
# device_class: "current"
# unit_of_measurement: A
# name: ${friendly_name} Sum Line Current
# address: 0x0030
# value_type: FP32
# address: 0x0034
# value_type: FP32
# name: ${friendly_name} Total System VA
# address: 0x0038
# value_type: FP32
# device_class: ""
# unit_of_measurement: VA
# name: ${friendly_name} Total System VAr
# address: 0x003C
# value_type: FP32
# device_class: ""
# unit_of_measurement: VAr
# name: ${friendly_name} Total System Power Factor
# address: 0x003E
# value_type: FP32
# device_class: "power_factor"
# unit_of_measurement: ""
name: ${friendly_name} Import Active Energy
register_type: read
address: 0x0048
value_type: FP32
name: ${friendly_name} Export Active Energy
register_type: read
address: 0x004A
value_type: FP32
# name: ${friendly_name} Neutral Current
# address: 0x00E0
# value_type: FP32
# name: ${friendly_name} Total Reactive Energy
# address: 0x0158
# value_type: FP32
# unit_of_measurement: kVArh
# state_class: "total_increasing"
# device_class: "energy"
# name: ${friendly_name} Net kwh (Import - Export)
# address: 0x018C
# value_type: FP32
# unit_of_measurement: kWh
# name: ${friendly_name} Total Import Active Power
# address: 0x0500
# value_type: FP32
# name: ${friendly_name} Total Export Active Power
# address: 0x0502
# value_type: FP32
# Power
name: ${friendly_name} Phase 1 Power
register_type: read
address: 0x000C
value_type: FP32
# Volts
name: ${friendly_name} Phase 1 Voltage
register_type: read
address: 0x0000
value_type: FP32
# Current
name: ${friendly_name} Phase 1 Current
register_type: read
address: 0x0006
value_type: FP32
# Apparent Power
name: ${friendly_name} Phase 1 Apparent Power
register_type: read
address: 0x0012
value_type: FP32
device_class: ""
# Reactive Power
# name: ${friendly_name} Phase 1 Reactive Power
# address: 0x0018
# value_type: FP32
# device_class: ""
# Power Factor
# name: ${friendly_name} Phase 1 Power Factor
# address: 0x001E
# value_type: FP32
Hope this helps someone in the future
ijhammo
(Ijhammo)
April 22, 2024, 12:46pm
3
Hi @clarky860 what hardware are you using to do this?
I have an SMD230 in my consumer unit that feeds my solar inverter, but I would like to get all the readings from it directly in to HA as well.
clarky860
(Alistair Clark)
May 9, 2024, 9:34am
4
Hi Sorry for the late reply, I never got a notification that you had replied to me.
Im using an ESP32-WROOM-32 board
And TTL to RS485
thank you for your code. i am looking for a long time to monitor my sdm230 in the HA dashboard
i will test them in a view weeks
cristitttt
(Cristitttt)
October 3, 2024, 12:42pm
6
i try your seting and don:t work .please help me with seting
clarky860
(Alistair Clark)
October 3, 2024, 1:08pm
7
Here it is again with the full code I have now after several updates to ESPHOME
esp32:
board: nodemcu-32s
framework:
type: arduino
version: 2.0.6
# Enable logging
logger:
baud_rate: 0
api:
encryption:
key: "YOUR KEY HERE IF YOU USE ONE"
ota:
platform: esphome
password: "YOUR PASSWORD HERE IF YOU USE ONE"
wifi:
ap:
password: "PASSWORD"
captive_portal:
switch:
- platform: restart
web_server:
port: 80
time:
#serial port
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
stop_bits: 1
modbus:
uart_id: mod_uart
modbus_controller:
- id: SDM230M
modbus_id: mod_bus
address: 1
setup_priority: -10
update_interval: 2s
# General
# address: 0x0046
# value_type: FP32
# address: 0x0034
# value_type: FP32
register_type: read
address: 0x0156
value_type: FP32
# address: 0x002A
# value_type: FP32
# address: 0x002E
# value_type: FP32
# address: 0x0030
# value_type: FP32
# address: 0x0034
# value_type: FP32
# address: 0x0038
# value_type: FP32
# device_class: ""
# address: 0x003C
# value_type: FP32
# device_class: ""
# address: 0x003E
# value_type: FP32
register_type: read
address: 0x0048
value_type: FP32
register_type: read
address: 0x004A
value_type: FP32
# address: 0x00E0
# value_type: FP32
# address: 0x0158
# value_type: FP32
# address: 0x018C
# value_type: FP32
# address: 0x0500
# value_type: FP32
# address: 0x0502
# value_type: FP32
# Power
register_type: read
address: 0x000C
value_type: FP32
# Volts
register_type: read
address: 0x0000
value_type: FP32
# Current
register_type: read
address: 0x0006
value_type: FP32
# Apparent Power
register_type: read
address: 0x0012
value_type: FP32
device_class: ""
# Reactive Power
# address: 0x0018
# value_type: FP32
# device_class: ""
# Power Factor
# address: 0x001E
# value_type: FP32
Hope it helps
thx for configuration
unfortunatly don"t work
gryzli133
(Marek Piechota)
December 16, 2024, 4:13pm
10
Hi, what was the problem? I have SDM630 working, but cannot get SDM230M to work in different location. The only difference is, one is WiFi, other one is Ethernet
