Hello everyone,
I would like to integrate a smart meter Eastron sdm630 v3 in HomeAssistant 2023.11 (untouched
fresh system on Raspberry 4b 4GB), with a USB to RS485 Cable Built-in FTDI chip.
I have not yet been able to find any instructions for this, so I would be very grateful for your help.
Thank you very much for your help
configuration.yaml
modbus:
- name: SDM630
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
sensors: !include sdm630_addresses.yaml
Source: https://www.home-assistant.io/integrations/modbus/#configuring-serial-connection
sdm630_addresses.yaml (only one register to test)
- address: 0
count: 2
data_type: float32
input_type: input
name: Phase 1 line to neutral volts
precision: 2
slave: 1
unit_of_measurement: Volts
Source: Copy & Paste from various sources on the internet
Error message YAML configuration reloading
Failed to call service homeassistant/reload_all.
Cannot quick reload all YAML configurations because the configuration is not valid:
Invalid config for [modbus]: Phase 1 line to neutral volts: `count: 2` cannot be combined with `data_type: float32` @ data['modbus'][0]['sensors'][0]. Got {'address': 0, 'count': 2, 'data_type': 'float32', 'input_type': 'input', 'name': 'Phase 1 line to neutral volts', 'precision': 2, 'slave': 1, 'unit_of_measurement': 'Volts', 'scan_interval': 15}.
(See /config/configuration.yaml, line 13).
