Easy automation - light
Dear all,
thanks first for your help.
I test some automations with my outside lights but the trigger is not working. The lights doensnt turn off/on with the automation.
My groups:
    licht_vorgarten:
    entities:
    - light.eingangstuer_links
    - light.eingangstur_rechts
    licht_terasse:
    entities:
    - light.lampe_links
    - light.lampe_rechts
and my automation:
- id: outdoor_light_at_night
alias: Outdoor lights at night
initial_state: ‘on’
platform: sun
event: sunset
offset: “00:45:00”
- service: homeassistant.turn_on
entity_id:
- group.licht_vorgarten
  • id: outdoor_light_off_midnight
    alias: ‘Turn off Light at Midnight’
    platform: time
    at: ‘20:00:00’
    service: homeassistant.turn_off
    entity_id:
  • id: testlight
    alias: test
    platform: time
    at: ‘20:15:00’
    service: light.turn_off
    entity_id: light.lampe_rechts
The last automation is a test and the automation works if I click on trigger at the dashboard. Then the light goes off. But it doesnt turn off with the time … do you have any idea?
Enviroment:
Hassbian on PI3
Thanks.
Best regards
The entities in the groups are not indented correctly, add 2 spaces
Thanks for your answer.
One more question. In the examples I see sometimes:
and
What I have to use?
BR
alkru002
You can use whichever you like, light.turn_off/on is specifically for lights, switch.turn_off/on is for switches and homeassistant.turn_off/on can be used on scenes, scripts etc as well as lights and switches, so it depends on what you are trying to turn on/off.
I think you are correct to use homeassistant.turn_off/on as you are trying to turn_on/off a group :slight_smile:
found my mistake… time zone was wrong :slight_smile:
Thanks for your help!!!
