Easy configuration for an Onvis HS2 Smart Button (5-Button)
This blueprint helps you to configure the Onvis HS2 Smart Button.
You need (obviously) an Onvis HS2 Smart Button and a Thread Border Router to use it. After that you can configure actions for a single press, double press or long press for each of the 5 physical buttons on the switch.
Event based:
Old Version:
This version is only compatible with the HS2. If there are any other smart buttons which uses the same syntax for labelíng the buttons it might also work these buttons.
Recent updates:
04.03.2024: I rewrote the blueprint to use more basic events to increase reliability
26.01.2024: fixed a typo which resulted in button 5 double-press and long-press not responding
blueprint:
  name: Onvis Smartswitch HS2 - event based
  description: Easily setup your Onvis HS2 5-Button Smartswitch
  domain: automation
  input:
    onvis_smartswitch:
      name: Onvis HS2 Switch
      description: Select your Onvis HS2 Switch you want to configure actions for.
      selector:
        device:
          filter:
          - model: HS2
          multiple: false
    button1_sp:
      name: Action SP Button 1
      default:
      description: Action Type for single pressing Button 1
      selector:
        action: {}
    button1_dp:
      name: Action DP Button 1
      default:
      description: Action Type for double pressing Button 1
      selector:
        action: {}
    button1_lp:
      name: Action LP Button 1
      default:
      description: Action Type for long pressing Button 1
      selector:
        action: {}
    button2_sp:
      name: Action SP Button 2
      default:
      description: Action Type for single pressing Button 2
      selector:
        action: {}
    button2_dp:
      name: Action DP Button 2
      default:
      description: Action Type for double pressing Button 2
      selector:
        action: {}
    button2_lp:
      name: Action LP Button 2
      default:
      description: Action Type for long pressing Button 2
      selector:
        action: {}
    button3_sp:
      name: Action SP Button 3
      default:
      description: Action Type for single pressing Button 3
      selector:
        action: {}
    button3_dp:
      name: Action DP Button 3
      default:
      description: Action Type for double pressing Button 3
      selector:
        action: {}
    button3_lp:
      name: Action LP Button 3
      default:
      description: Action Type for long pressing Button 3
      selector:
        action: {}
    button4_sp:
      name: Action SP Button 4
      default:
      description: Action Type for single pressing Button 4
      selector:
        action: {}
    button4_dp:
      name: Action DP Button 4
      default:
      description: Action Type for double pressing Button 4
      selector:
        action: {}
    button4_lp:
      name: Action LP Button 4
      default:
      description: Action Type for long pressing Button 4
      selector:
        action: {}
    button5_sp:
      name: Action SP Button 5
      default:
      description: Action Type for single pressing Button 5
      selector:
        action: {}
    button5_dp:
      name: Action DP Button 5
      default:
      description: Action Type for double pressing Button 5
      selector:
        action: {}
    button5_lp:
      name: Action LP Button 5
      default:
      description: Action Type for long pressing Button 5
      selector:
        action: {}
trigger_variables:
  var_device_id: !input onvis_smartswitch
- platform: event
  event_type: state_changed
  event_data:
    entity_id:  "{{ device_entities(var_device_id)[0] }}" #device_entities(!input onvis_smartswitch)[0]
- platform: event
  event_data:
    entity_id:  "{{ device_entities(var_device_id)[1] }}"
- platform: event
  event_data:
    entity_id:  "{{ device_entities(var_device_id)[2] }}"
- platform: event
  event_data:
    entity_id:  "{{ device_entities(var_device_id)[3] }}"
- platform: event
  event_data:
    entity_id:  "{{ device_entities(var_device_id)[4] }}"
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - choose:
              - conditions:
                  - condition: template
                    value_template: '{{ trigger.event.data.new_state.attributes.event_type == ''single_press'' }}'
                sequence: !input button1_sp
              - conditions:
                    value_template: '{{ trigger.event.data.new_state.attributes.event_type == ''double_press'' }}'
                sequence: !input button1_dp
              - conditions:
                    value_template: '{{ trigger.event.data.new_state.attributes.event_type == ''long_press'' }}'
                sequence: !input button1_lp
      - conditions:
        sequence:
          - choose:
              - conditions:
                sequence: !input button2_sp
              - conditions:
                sequence: !input button2_dp
              - conditions:
                sequence: !input button2_lp
      - conditions:
        sequence:
          - choose:
              - conditions:
                sequence: !input button3_sp
              - conditions:
                sequence: !input button3_dp
              - conditions:
                sequence: !input button3_lp
      - conditions:
        sequence:
          - choose:
              - conditions:
                sequence: !input button4_sp
              - conditions:
                sequence: !input button4_dp
              - conditions:
                sequence: !input button4_lp
      - conditions:
        sequence:
          - choose:
              - conditions:
                sequence: !input button5_sp
              - conditions:
                sequence: !input button5_dp
              - conditions:
                sequence: !input button5_lp
Hi @Nemesis , can you share some insights on how you connected the HS2 to your thread network?
I have a google nest hub2 as border router and it works fine with Onvis smart plugs and other thread/matter devices in HA.
But I could only connect the the HS2 button with bluetooth via HomeKit integration and then triggered the “set preferred thread credentials” action in the device.
But since then it disappeared from HA completely…
It healed itself, After one hour the button appeared back in HomeKit. For anyone wondering about the process:
  1. Add bluetooth to HA
  2. Connect the Button over BT via HomeKit integration
  3. In device details under COnfiguration press “Provision Preferred Thread Credentails”
  4. Wait. Button disappears from HomeKit integration but after some time it will be back with Thread Status “Kind”
Hi Smetti,
thanks for your tip. Before i added it to the “home”-app on iphone, waited a bit until it is connected to the thread network, deleted it from the home-app and then added it into home-assistant but your solution works way better! Thanks!
I rewrote the blueprint to use the more basic event-handling in home assistant to improve reliability.
I had problems that the button presses were not recognised by the automation but within home assistant. I hope this helps.
Apologies for my ignorance, I’m relatively new to HA.
But what does this blueprint actually do?
I ended up here because I have an HS2, and I imported it into Apple Home and had it setup and working. But then had an issue (think I hit the max number of devices through one HomeKit bridge). So I redistributed my devices into HomeKit through separate bridges, and now my HS2 appears in Apple Home with only 2 buttons shown :confused: they all show in HA still and respond so I thought I’d add this blueprint to see if it would help me?
Ugh nothing worse than it working again and not knowing why! I see all 15 button combos again now :confused:
Thanks for sharing the blueprints.
When trying this one out myself for my own Onvis HS2, only the middle button worked and that one was recognized as Button 5. Turns out that device_entities returns the entities in different orders. For me, it was:
['sensor.onvis_hs2_battery', 'button.onvis_hs2_identify', 'event.onvis_hs2_stateless_programmable_switch_1', 'event.onvis_hs2_stateless_programmable_switch_2', 'event.onvis_hs2_stateless_programmable_switch_3', 'event.onvis_hs2_stateless_programmable_switch_4', 'event.onvis_hs2_stateless_programmable_switch_5', 'sensor.onvis_hs2_thread_capabilities', 'sensor.onvis_hs2_thread_status']
So I had to make a small adjustments to make sure it really only picked up the 5 events:
  - platform: event
    event_data:
      entity_id: "{{ (device_entities(var_device_id) | select('match','event') | list)[0] }}"
  - platform: event
    event_data:
      entity_id: "{{ (device_entities(var_device_id) | select('match','event') | list)[1] }}"
  - platform: event
    event_data:
      entity_id: "{{ (device_entities(var_device_id) | select('match','event') | list)[2] }}"
  - platform: event
    event_data:
      entity_id: "{{ (device_entities(var_device_id) | select('match','event') | list)[3] }}"
  - platform: event
    event_data:
      entity_id: "{{ (device_entities(var_device_id) | select('match','event') | list)[4] }}"
With this, it works reliably for me.
Same issue, seems your fix works perfectly though!
Howdy All… I’ve been struggling with my Onvis button since the last core update. I used to power button presses with individual automations that let me select what button was pressed and how many times (ie single press, double, and long press), and all of a sudden the ability to select the individual buttons disappeared from HA. I just imported this template for the button automations and they work intermittently. Did something change in the HA core software that needs correcting to fix these issues?
So you see the Button presses in the overview of the device?
I do. I have the button connected to my pi with the skyconnect thread fob and can see the button presses show up almost immediately.
The button is showing connected to my thread network and no issues. I suppose I assume something changed because I did have the button set up months ago and its been working flawlessly until just recently.
these are the options for the button that I’m seeing available in HA now.
EDIT… the core update that just rolled out fixed the problem.
This largely worked for me (thank you), but my buttons are mixed up.
Blueprint button 2 is button 5 on the Onvis, 3 is 4, 4 is 3, and 5 is 2. Any idea how to fix this so the blueprint and buttons align?
i don’t know if they changed anything in their hardware. But in my system the buttons are stil ok. nothing mixed. It should be easy to work around this.
It’s strange, for me the order button are correct, but with automation when I configure for single press, I have to do a double press for it to trigger and conversely the double press is triggered by the single. however on the device itself the vents are good, but reverse for automation
I have two of these buttons. Just recently purchased the second. The first one works great. Have it connected over thread and love it. I have tried like crazy to get the second one added but can’t. The first one I just added it to apple home, the removed it and added it to Hass. I have tried the Apple homekit method as well as using a bluetooth proxy and just can;t get it to connect. Wonder if anyone has any pointers or if having two is the issue. Anyone have two of these without any issues. Wonder if something has changed since I added the last one. When I do the homekit method I get the constant this device is already paired with another controller. When I do the bluetooth proxy, it times out and cant connect even though the device pops up under settings/devices to add
