Easy Custom Aquara H1 Switch Automation for Z2M(Zigbee2MQTT)
Hi Everyone! :slight_smile:
I made an very easy customizable Blueprint for the Aquara H1 Switch.
Requirements:
  • Running MQTT Broker & MQTT Integration in Home Assistant
  • Running Zigbee2MQTT
  • Aquara H1 Switch
For more Information, just ask!
blueprint:
  name: Easy Custom Actions for Aquara Switch Model H1
  description: Easy Custom Automation for executing press/hold/doubleclick for Aquara Switches Model H1
  domain: automation
  input:
    # MQTT Config
    controller:
      name: (Zigbee2MQTT) Controller Name
      description: The name of the controller/Dimmer-Switch in Zigbee2MQTT (Not the name of your Home-Assistent Entity)
      default: ""
    base_topic:
      name: Root/Base mqtt topic from Zigbee2MQTT
      description: The Root/base topic as configured in Zigbee2MQTT (If you dont configured it you can leave the default --> "zigbee2mqtt")
      default: zigbee2mqtt
      # Define Buttons
    button_1_pressed:
      name: Button Left Pressed
      description: Action to run, when Button Left is pressed.
      default: []
      selector:
        action: {}
    button_1_held:
      name: Button Left Held
      description: Action to run, when the Button Left is held.
      default: []
      selector:
        action: {}
    button_1_doubleclicked:
      name: Button Left doubleclicked
      description: Action to run, when the Button Left is doubleclicked.
      default: []
      selector:
        action: {}
    button_2_pressed:
      name: Button Right Pressed
      description: Action to run, when the Button Right pressed.
      default: []
      selector:
        action: {}
    button_2_held:
      name: Button Right Held
      description: Action to run, when the Button Right is held.
      default: []
      selector:
        action: {}
    button_2_doubleclicked:
      name: Button Right doubleclicked
      description: Action to run, when the Button Right is doubleclicked.
      default: []
      selector:
        action: {}
    Both_Buttons_pressed:
      name: Both Buttons Pressed
      description: Action to run, whe Both Buttons pressed.
      default: []
      selector:
        action: {}
    Both_Buttons_held:
      name: Both Buttons Held
      description: Action to run, when Both Buttons held.
      default: []
      selector:
        action: {}
    Both_Buttons_doubleclicked:
      name: Both Buttons doubleclicked
      description: Action to run, when Both Buttons doubleclicked.
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
trigger_variables:
  base_topic: !input base_topic
  controller: !input controller
  - platform: mqtt
    topic: "{{ base_topic ~ '/' ~ controller }}"
condition:
  - condition: template
    value_template: "{{(trigger.payload_json.action is defined)}}"
  - variables:
  - choose:
      - conditions: "{{trigger.payload_json.action is defined}}"
        sequence:
          - choose:
              - conditions: '{{ trigger.payload_json.action == "single_left" }}'
                sequence: !input button_1_pressed
              - conditions: '{{ trigger.payload_json.action == "single_right" }}'
                sequence: !input button_2_pressed
              - conditions: '{{ trigger.payload_json.action == "single_both" }}'
                sequence: !input Both_Buttons_pressed
              - conditions: '{{ trigger.payload_json.action == "hold_left" }}'
                sequence: !input button_1_held
              - conditions: '{{ trigger.payload_json.action == "hold_right" }}'
                sequence: !input button_2_held
              - conditions: '{{ trigger.payload_json.action == "hold_both" }}'
                sequence: !input Both_Buttons_held
              - conditions: '{{ trigger.payload_json.action == "double_left" }}'
                sequence: !input button_1_doubleclicked
              - conditions: '{{ trigger.payload_json.action == "double_right" }}'
                sequence: !input button_2_doubleclicked
              - conditions: '{{ trigger.payload_json.action == "double_both" }}'
                sequence: !input Both_Buttons_doubleclicked
