Easy Custom Lidl / Silvercrest Smart Button for Z2M(Zigbee2MQTT)
Hi Everyone! :slight_smile:
I made an easy (at least as easy as it can be) customizable Blueprint for the Lidl / Silvercrest Smart Button.
Requirements:
- Running MQTT Broker & MQTT Integration in Home Assistant
- Running Zigbee2MQTT
- Lidl / Silvercrest Smart Button
This Button is very tricky, so be sure to read the Blueprint description carefully!
For more Information, just ask!
blueprint:
  name: Easy Customizable Controller Automation Blueprint for Lidl Smart Button in Zigbee2MQTT
  description:
    Controller automation for easy customizable Actions with Lidl Smart Button.
    __-------->  !!!!!!!!! FRUSTRATION CAUTION !!!!!!!!!   <--------__
    _______________________________██████
    ___________________________███████████
    ______________________________███████
    __________________________________██
    __This Button is very unique in its way to operate and makes some actions very inconvenient.__
    __The Control on Hold is Firmware based and cannot be Customized!__
    __The hold button is first stepping up 3 times then stepping down 4 times.__
    __Trippleclick is locking the Button it can only be unlocked by tripple clicking again! (also Firmware)__
    __After you doubleclick you're not able to use the on hold feature only the on hold release.__
    __You need to single click to activate the hold feature again__
  domain: automation
  # Input from MQTT
  input:
    controller:
      name: (Zigbee2MQTT) Controller Name
      description: The name of the controller/Dimmer-Switch in Zigbee2MQTT (Not the name of your Home-Assistent Entity)
      default: ""
    base_topic:
      name: Root/Base mqtt topic from Zigbee2MQTT
      description: The Root/base topic as configured in Zigbee2MQTT (If you dont configured it you can leave the default --> "zigbee2mqtt")
      default: zigbee2mqtt
    # Define Actions to the Buttons
    Button_single_click:
      name: Button singleclick
      description: Action set to run, when you press the Button once.
      default: []
      selector:
        action: {}
    Button_double_click:
      name: Button doublekclick
      description: Action set to run, when you press the Button twice.
      default: []
      selector:
        action: {}
    button_hold_going_up:
      name: Button Hold increase
      description: Action set to run, when the Button is held for a short while. (unstable cause of Buttons Firmware)
      default: []
      selector:
        action: {}
    button_hold_going_down:
      name: Button Hold decrase
      description: Action set to run, when the Button is held for a long while. (unstable cause of Buttons Firmware)
      default: []
      selector:
        action: {}
    release_hold:
      description: Action set to run, when the Up is held.
      default: []
      selector:
        action: {}
# Link the Defined Action to the Buttons
mode: parallel
max: 6
trigger_variables:
  base_topic: !input base_topic
  controller: !input controller
  - platform: mqtt
    topic: "{{ base_topic ~ '/' ~ controller }}"
  - variables:
  - choose:
      - conditions: "{{('brightness' in trigger.payload_json.action) or ('on' in trigger.payload_json.action) or 'off' in trigger.payload_json.action}}"
        sequence:
          - choose:
              - conditions: '{{ trigger.payload_json.action == "on" }}'
                sequence: !input Button_single_click
              - conditions: '{{ trigger.payload_json.action == "off" }}'
                sequence: !input Button_double_click
              - conditions: '{{ trigger.payload_json.action == "brightness_step_up" }}'
                sequence: !input button_hold_going_up
              - conditions: '{{ trigger.payload_json.action == "brightness_step_down" }}'
                sequence: !input button_hold_going_down
              - conditions: '{{ trigger.payload_json.action == "brightness_stop" }}'
                sequence: !input release_hold
