Hi guys, I’m trying a simple script but for some reasons (probably stupid) it won’t work.
Working script has a hard coded value:
set_ahs_temp_for_pdc:
alias: "Set the temp for AHS"
fields:
temp:
description: "AHS temp"
sequence:
- service: modbus.write_register
hub: hub_term
slave: 1
address: 237
value: 13
Not working script uses the variable temp instead of the hard coded number
fields:
temp:
sequence:
hub: hub_term
slave: 1
address: 237
value: "{{ temp }}"
When I try to use the script this error is shown
expected dict for dictonary value @data['service_data']. Got 13
Where 13 is the value that I’m trying to pass it.
