Easy Time Macros for Templates!
you can apply what Pieter said w/ easy_time too
{% from 'easy_time.jinja' import easter %}
{{ (easter() | as_datetime).date() }}
But if you want to use these things for automations, you should really just use the output from the template as-is, that’s how it’s designed.
Thank you both - that works perfectly. On the second item, is there a way to show the day of the week for a future date such as 12/25/2024 (which day Christmas falls on)?
You can do…
{% from 'easy_time.jinja' import weekday %}
{{ weekday(('2024-12-25' | as_datetime).isoweekday()) }}
Or if you want one to work every year…
{% from 'easy_time.jinja' import weekday, month_day %}
{{ weekday((month_day(12,25) | as_datetime).isoweekday()) }}
or broken apart…
{% set christmas = month_day(12,25) | as_datetime %}
{{ weekday(christmas.isoweekday()) }}
Hi, still loving this set of macro’s and have a small question.
Why would one not import all macro’groups’ at once, instead of only the ones needed, is this performance related?
that is nice… now how do I get from a custom_template with my anniversaries to a useable input for that day template…
{% set vj_marijn = '1964-08-27'|as_datetime|as_local %}
I can use this:
{% from 'feestdata.jinja' import vj_marijn %}
{% set event = vj_marijn %}
{% set datum = event.strftime('%-m,%d') %}
{{datum}}
which outputs 8,27, but when I add it in the template you showed above,
and do
{{ weekday((month_day(datum) | as_datetime).isoweekday()) }}
it says
TypeError: ‘str’ object cannot be interpreted as an integer
ofc, I can not |int it either
You know the answer to this. vj_marijn is a datetime object, how do you get month and day out of it as an integer? You’ve used this many times.
yeah, I guess
{{ weekday((month_day(vj_marijn.month,vj_marijn.day) | as_datetime).isoweekday()) }}
works ok.
or, shorter:
{{ weekday((month_day(event.month,event.day) | as_datetime).isoweekday()) }}
it was probably me figuring I am overdoing things here.
Have this bigger template: with all sorts of attributes, and this month, day combo could be added there, and next use it in a template-entity-row card, where I currently do this:
card:
  type: custom:template-entity-row
  entity: '[[entity]]'
    {% set dagen = states(config.entity)|int(default=-1) %}
    {% if dagen == 0 %}
    {{state_attr(config.entity,'id')}} is vandaag:
    {% else %}
    {{state_attr(config.entity,'id')}} wordt {{state_attr(config.entity,'leeftijd')
      |int(default=-1) + 1}} over:
    {% endif %}
  state: >
    {% if dagen == 0 %} Jarig!
    {% else %} {{states(config.entity)}} {{'dag' if over == 1 else 'dagen'}}
    {% endif %}
  secondary: >
    {% set event = state_attr(config.entity,'datum')|default(0,true)|as_datetime|as_local %}
    {{state_attr(config.entity,'type')}}: {{event.strftime('%d-%m-%Y')}}
and only reference the config.entity
so I can use eg:
  secondary: >
    op {{weekday((month_day(event.month,event.day)|as_datetime).isoweekday())}}
I’m currently just trying to convert minutes so that something comes out with x hours and x minutes.
However, something always comes up for me within weeks.
I didn’t fully understand what was wrong. I tried different marcros
{% from 'easy_time.jinja' import custom_time %}
      {{ custom_time(120, 'hour') }}
→ 476942 Stunden
  {% from 'easy_time.jinja' import custom_relative_time %}
   {{ custom_relative_time(120) }}
→ 838 Wochen, 6 Tagen, 14 Stunden, 25 Minuten und 39 Sekunden vor
These macros look for timestamps, timestrings, timedeltas, or entity_ids. So you have to provide one of those. A small integer (in seconds) is not supported, well it is, but it assumes it’s a timestamp. 120 is 120 seconds past january 1st 1970, not exactly what you’d be looking for.
Depending on where you want to use this, you could also work with the template function time_until or time_since.
Not that I would want to discourage you from using the easy time macro, using it myself a lot, but sometimes templating is another way… :slight_smile:
Those also only work with datetimes or entity_id’s.
They sure do, like practically everything else in HA related to date, time and mathematical operations. What else would one use than a date/time related format?
Even if you have minutes or seconds, you can convert that to a timestamp and use it, or am I off here?
You’re off here, just try it
{{ time_since(120) }}
{{ time_until(120) }}
{{ time_since(now()-timedelta(seconds=120)) }}
{{ time_until(now()+timedelta(seconds=120)) }}
{{ relative_time(now()) }}
Sorry, you misunderstood or I wasn’t clear, I’m totally with you on that one aka. that’s what I’m saying or trying to say… :rofl: :rofl:
Ah, I thought you ment “they sure do accept ints”
Sorry, not my best english-is-not-my-native-language-day… :rofl: :rofl:
I’m trying to learn Italian at the moment, and I can safely say it doesn’t make my english better… :rofl: :rofl: Not to talk about my native language German, getting a mix out of english, german and italian is mostly funny for others… :rofl: :rofl:
Thanks understood the issue :).
EDIT: @petro do you think also an option with capitalize make sense?
See idea from button card helpers:
Is there a way of calculating the time until each season change with this?
Yes, you can use one of the many functions. easy_time, count_the_days, easy_time_between, etc.
Thanks, but does easy_time “know” the date and time of the season changes?
