Like the title says is there an easy way to back up my Home Assistant configuration to github without having to ssh in? I currently have my set up on a Pi and am using Hassio.
I know there is a git pull add-on and am hoping that some one made a git push add-on that I just can’t find.
If not, I was hoping someone might have an easy way of doing it.
Another option is to use the IDE addon if your using HassIO.
It allows you to open a console into HomeAssistant. I use this to do commits and pushes from my local configuration into GitHub with shell commands, similar to over SSH, but never having to leave the webUI.
I don’t use Github for backups, although i probably should.
Looking at the configurator docs you have to setup the remote repository manually so you will have to ssh just for setup.
For option 1 again it will be ssh for initial setup then you would just have a button in HA
If you want only ssh as @Silicon_Avatar suggested then there’s also
although IDE looks very interesting and looks like it may have github support too
