I have a datetime helper I’m using for my kid’s wake up routine. I would like to be able to change the wake up time directly from the dashboard if needed. Currently, the closest I’ve been able to come is to add a card that shows the wake up time and when you tap/click on it you can change the value. Unfortunately, this is not meeting the WAF.
Is there either a way to change the time directly from the dashboard or display a card similar to how you would change the alarm time on an iPhone when you click on it. Any suggestions would be appreciated.
