Hello I was wondering if anyone that has a WaterAir Pool and is using their connected automation system based on Lora, has successfully integrated it with Home Assistant?
Hi @ursus69
Do you find any solution ?
Nope, none whatsoever. Nor from the community nor from Waterair
Cordially
Same here, still doing some researchâŚ
Hi
Did you find a solution ? and if so what is the product ? as I canât find it on internet and looking as you for a Lora sensor for pool
Vincèn
I made a custom components for Waterair and I work also on a custom card :
You can find the git repository for the custom components here :
https://github.com/yyrkoon94/ha-easycare-waterair
For now you can get all the information on the pool (temperature, ph, chlorine, alerts) and I continue to work on managing the lights and pump.
Let me know how it works if you try it
This is perfect! exactly what i was looking for, already installed and testing.
All the sensors are working Fine!
Many Thanks!
Hi @ursus69,
If you want, the first version of the Card is ready.
yyrkoon94/lovelace-easycare-waterair: Lovelace Card for EasyCare by Waterair (github.com)
You need to install the last Custom Component version (0.0.5) to make it works correctly.
Lights are coming soon
Enjoy !
