Hello everybody,
I hooked up my adapter to my heater, and so far everything seems to work, hardware talking.
Also when I connect via Wifi to the adapter, i see that the ebus is running
ebusd connected: no
eBUS signal: acquired
But i cant make Home Assistant connect to the adapter.
eBUS Adapter LOG
10:27:26
Info
execute: if "isio -l 6" "var rpi 1"
10:27:26
Info
execute: isio -l 6
10:27:26
IO 6 level 1 is unmet
10:27:26
Info
execute: var isnew 1
10:27:26
Info
execute: if "§isnvs ebus.host" "var isnew 0"
10:27:26
Info
execute: isnvs ebus.host
10:27:26
Info
execute: var isnew 0
10:27:26
Info
execute: if "§isnvs sta.on" "var isnew 0"
10:27:26
Info
execute: isnvs sta.on
10:27:26
Info
10:27:26
Info
execute: if "§isnvs eth.on" "var isnew 0"
10:27:26
Info
execute: isnvs eth.on
10:27:26
Warning
execute: command failed: isnvs eth.on = 1
10:27:26
Info
execute: on -lo iol 9 "led 0 255" "led 1 255" "led 2 255" "sleep 500" restart
10:27:26
io trigger installed
10:27:26
Info
execute: on iol 9 "led 2 50 0"
10:27:26
10:27:26
Info
execute: if "var skipstart" "led 0 255 0 5000" "led 2 50" "ap EBUS" server exit
10:27:26
Info
execute: var skipstart
10:27:26
variable skipstart = 0
10:27:26
Info
execute: function start server "led 0 10"
10:27:26
function installed
10:27:26
Info
execute: on wifi 1 start
10:27:26
network trigger installed
10:27:26
Info
execute: on eth 1 start
10:27:26
10:27:26
Info
execute: if "isnvs sta.on" "led 0 10 255 5000" "sleep 100" sta
10:27:26
Info
10:27:26
Info
execute: led 0 10 255 5000
10:27:26
Info
execute: sleep 100
10:27:26
Info
statusLedTimerFn: duty set to 10
10:27:26
Info
execute: sta
10:27:26
Warning
vfs: esp_vfs_register_fd_range is successful for range <52; 64) and VFS ID 3
10:27:26
Info
pp: pp rom version: 9387209
10:27:26
Info
net80211: net80211 rom version: 9387209
10:27:26
Info
wifi_init: accept mbox: 6
10:27:26
Info
wifi_init: tcpip mbox: 32
10:27:26
Info
wifi_init: udp mbox: 6
10:27:26
Info
wifi_init: tcp mbox: 6
10:27:26
Info
wifi_init: tcp tx win: 5760
10:27:26
Info
wifi_init: tcp rx win: 5760
10:27:26
Info
wifi_init: tcp mss: 1440
10:27:26
Info
wifi_init: WiFi IRAM OP enabled
10:27:26
Info
wifi_init: WiFi RX IRAM OP enabled
10:27:26
Info
wifi_init: LWIP IRAM OP enabled
10:27:26
Info
phy_init: phy_version 1130,b4e4b80,Sep 5 2023,11:09:30
10:27:26
using individual IP: 192.168.20.9 / 255.255.255.0, gateway 192.168.20.1
10:27:26
sta connecting to 'LesEnfantsTerrible'
10:27:29
Info
cmd_wifi: sta connect, set fix ip
10:27:29
Info
repl_event_task: wifi event: 1
10:27:29
Info
execute: led 0 50
10:27:29
Info
execute: start
10:27:29
Info
execute: server
10:27:29
Info
esp-rest: Starting HTTP Server
10:27:29
server started
10:27:29
Info
execute: led 0 10
10:27:29
Info
execute: if "var isnew" "ap EBUS" else "if \"isnvs ap.on\" ap"
10:27:29
Info
execute: var isnew
10:27:29
variable isnew = 0
10:27:29
Info
execute: if "isnvs ap.on" ap
10:27:29
Info
execute: isnvs ap.on
10:27:29
Info
execute: var eth 0
10:27:29
Info
execute: if "eth -t" "var eth 1" else "if \"eth -wt\" \"var eth 2\""
10:27:29
Info
execute: eth -t
10:27:30
Error
w5500.mac: w5500_reset(302): reset timeout
10:27:30
Error
w5500.mac: emac_w5500_init(793): reset w5500 failed
10:27:30
Error
esp_eth: esp_eth_driver_install(228): init mac failed
10:27:30
Error
eth: initialise_ethernet(295): install driver
10:27:30
Ethernet on USR-ES1 not available
10:27:30
Warning
execute: command failed: eth -t = 1
10:27:30
Info
execute: if "eth -wt" "var eth 2"
10:27:30
Info
execute: eth -wt
10:27:31
Error
esp-rest: Failed to open file: /data/assets/index-qgRVZuPS.js
10:27:31
Warning
httpd_txrx: httpd_resp_send_err: 404 Not Found - File not found
10:27:31
Error
esp-rest: Failed to open file: /data/assets/index-IUdQemll.css
10:27:31
Warning
10:27:31
Error
esp-rest: Failed to open file: /data/index.html
10:27:31
Warning
10:27:31
Info
10:27:31
Error
10:27:31
Error
10:27:31
Error
10:27:31
Error
10:27:31
Ethernet on W5500 module not available
10:27:31
Warning
execute: command failed: eth -wt = 1
10:27:31
Info
execute: on -o server 2 "after -o -m 500 0 restart"
10:27:31
server trigger installed
10:27:31
Info
execute: io -a
10:27:31
Info
execute: function chkethcfg "if \"eth -c\" \"var eth 1\""
10:27:31
function installed
10:27:31
Info
execute: if "!var isnew" "if \"!var eth\" chkethcfg"
10:27:31
Info
execute: var isnew
10:27:31
variable isnew = 0
10:27:31
Info
execute: if "!var eth" chkethcfg
10:27:31
Info
execute: var eth
10:27:31
variable eth = 0
10:27:31
Info
execute: chkethcfg
10:27:31
Info
execute: if "eth -c" "var eth 1"
10:27:31
Info
execute: eth -c
10:27:31
Warning
execute: command failed: eth -c = 1
10:27:31
Info
execute: function enet eth "led 0 50" "led 1 50" "led 2 50"
10:27:31
function installed
10:27:31
Info
execute: if "isnvs eth.on" "if \"var eth\" enet"
10:27:31
Info
10:27:31
Warning
10:27:31
Info
execute: function ebusnvs ebus "led 0 50"
10:27:31
function installed
10:27:31
Info
execute: if "isnvs ebus.host" ebusnvs exit
10:27:31
Info
10:27:31
Info
execute: ebusnvs
10:27:31
Info
execute: ebus
10:27:31
Info
init_ebus: switching to enhanced eBUS mode on TCP port (with bitrate deviation 0 and enhanced arbitration delay 200 us)
10:27:31
Info
setup_uart: eBUS UART 1 on TX=10(inv) RX=7(inv) with 2400 Bd
10:27:31
Info
uart: ALREADY NULL
10:27:31
Info
host_task_tcp: listening
10:27:31
Info
init_ebus: timer started
10:27:31
Info
execute: led 0 50
10:27:31
Info
execute: exit
10:27:31
Info
execute: command exit
10:27:31
Info
10:27:31
Info
replExecuteFromFile: successfully executed 41/41 commands from '/data/main.eas'
10:27:31
Welcome to eBUS Adapter Shield Interface!
Type 'help' to get the list of commands.
10:27:31
Your terminal application does not support escape sequences.
10:27:31
10:27:31
Info
main_task: Returned from app_main()
10:27:31
Info
statusLedTimerFn: duty set to 50
10:27:33
Info
sntpTimeCb: got NTP time: 2024-01-23 09:27:36
10:27:53
Info
temperature_sensor: Range [-10°C ~ 80°C], error < 1°C
