Can anyone confirm if the EFR32MG12 based E180-ZG120B module from Ebyte works with ZHA?
Ebyte is making an inexpensive development board called “E180-ZG120B-TB” made for testing it.
This development is sold for less than $9 US-dollar on Aliexpress or about twice that on eBay UK:
- https://www.aliexpress.com/item/4000538003718.html
- https://www.ebay.co.uk/itm/EFR32-Zigbee-3-0-Test-Board-USB-Port-2-4GHZ-E180-ZG120B-TB-Test-Kit/233517910970
You can also buy them on bulk from Alibaba for less:
- Ebyte 2.4g Smart Home Wireless Mesh Zigbee Module E180-zg120b Zigbee 3.0 Module Usb Test Board Kit - Buy Zigbee Module,Zigbee Smart Home,Smart Home Zigbee Product on Alibaba.com
- Newest-zigbee-3-0-module-USB
Looks like you can remove some jumpers to disable the USB converter if want to use serial directly.
E180-ZG120B by Chengdu Ebyte (CDEYTE) has 20 dBM powerful Zigbee 3.0 radio for 2.4GHz capable based on an EFR32MG1 Series 1 MCU SoC / chip, specifically EFR32MG1B (IC = EFR32MG1B232F256GM48), from Silicon Labs EFR32 (“Mighty Gecko”) family.
EFR32MG1B232F256GM48 includes a 40 MHz ARM Cortex-M4 microcontroller with 256 Flash, 32 RAM and a rich peripheral set in a QFN48 package. With 19.5 dBm maximum output power and receive sensitivity of -101 dBm (250 kbps O-QPSK DSSS). Key Specs: 19.5 Output Power Max (dBm) / 120.5 Total Link Budget (dB).
I understand this also is classified as an Ember based radios using the EZSP (EmberZNet Serial Protocol) serial protocol (UART bus) interface so could therefore be made compatible with the bellows library for zigpy if the E180-ZG120B module is flashed with the right firmware?
I guess that my follow-up question will be which exact firmware to use on the E180-ZG120B module?
Ebyte is now making two EFR32MG1B based modules called E180-ZG120A and E180-ZG120B
E180-ZG120B modules by Ebyte (and their previous E180-ZG120A) seem now to be readily available as sold on Aliexpress and eBay at relatively low prices.
Example:
Perhaps this board could dethrone Nortek HUSBZB-1 for ZHA as the new must-have Zigbee adapter?
