I just went to amazon music and searched for “sounds ding dong” there looks to be an album called DV Sound effects" and one of the sounds is doorbell ding dong. not sure how good or bad it is, but it looks like it might be what you need
edit: thanks, there are a lot of fun sound effects here, now I think I’m going to have to set up some silly automations!! haha
Try finnolia sound effects? If that does not work, maybe another music service you have access to. I’ll stop posting for now, since this is more of a “where can I find a sound effect” and less of a “how” at least as far as help I can offer. Good luck, if you find the sound, and create the automation, go ahead and post for others.
Hi everyone, running into some issues with the configuration. I am based in the US and have 2FA enabled on my Amazon account. I am running .88.2 on RPI. I have followed instructions from this link for versions > 1.0. The component shows in HA waiting to be configured. I get this prompt :
2 issues here : first it is asking me to re-enter the password. Not sure where ? Second the CAPTCHA is actually missing. Now, I can enter anything, submit, and then press “Configuration” again, this time I do see a CAPTCHA, I enter it but then back to the same state again.
My config file has :
In secrets I have my username and password contained in “”. I have tried without “”, does not seem to make a difference.
It is possible to create a routine to play music from “My Library”. Not sure what “My Library” is, but if you could get the sound you want into “My Library”, maybe you could just trigger the routine from HA. Of course it may require a one time fee to purchase the sound to put into “My Library”.
Thanks @alandtse. I changed my config file removing the !secret and replacing with my actual email and password, rebooted and got the same result. The first captcha with no image asking to re-enter my password, then failing all CAPTCHAs. Not sure what I am doing wrong. Also, sorry if this is basic, but I do not see what is different between my original config I pasted and the one you edited… Thanks for your help !
Thanks @alandtse, after correcting my mistake on the use of secrets syntax and removing the " " both username and password in the Secrets file, I successfully configured. I did get the first CAPTCHA prompt with a blank image, clicked through then hit configure again, this time it came up with a CAPTCHA image and it worked. I received a text on my phone with the Amazon code, entered that and…success…thank you.
Is it possible to rename the “this device” device. I don’t mean a friendly name. I mean changing it in the alexa app, so that the media player entity shows up different. “This device” is a bad name.
Please follow these instructions exactly. You should update to 1.1.0 per the instructions. We are not supporting any lower version (e.g., 0.10.2) and with HA releasing breaking changes, there may be issues we probably won’t fix .
