This means you have a tab in your automations.yaml file…
OK, that fixes my automation error, but my tts is still not working. Alexa still says “Sorry text to speech to only be called with a media player alexa tts service” if I try and enter something for alexa to say.
As far as I know you need to go the services tab, select media_player.alexa and in the payload write some valid json.
I haven’t actually got this component working yet so can’t comment, but that’s how other tts services work
Hi all!
I wanted to make sure I have everything setup properly. I can’t even get the media_player.alexa to show up.
Im running Hassio 0.74.2
I did install the add-on im not sure if that should be taken out or not.
alexa.py version 7.1 Placed in www/custom_components/media_player
Support to interface with Alexa Devices.
For more details about this platform, please refer to the documentation at
https://community.home-assistant.io/t/echo-devices-alexa-as-media-player-testers-needed/58639
VERSION 0.7.1
import json
import logging
from datetime import timedelta
import requests
import voluptuous as vol
from bs4 import BeautifulSoup
from homeassistant import util
from homeassistant.components.media_player import (
MEDIA_TYPE_MUSIC, PLATFORM_SCHEMA,SUPPORT_NEXT_TRACK,
SUPPORT_PAUSE, SUPPORT_PLAY, SUPPORT_PREVIOUS_TRACK,
SUPPORT_STOP, SUPPORT_TURN_OFF, SUPPORT_VOLUME_MUTE,
SUPPORT_PLAY_MEDIA, SUPPORT_VOLUME_SET,
MediaPlayerDevice, DOMAIN, MEDIA_PLAYER_SCHEMA,
SUPPORT_SELECT_SOURCE)
from homeassistant.const import (
CONF_EMAIL, CONF_PASSWORD, CONF_URL, STATE_UNKNOWN,
STATE_IDLE, STATE_OFF, STATE_STANDBY, STATE_PAUSED,
STATE_PLAYING)
from homeassistant.helpers import config_validation as cv
from homeassistant.helpers.service import extract_entity_ids
from homeassistant.helpers.event import track_utc_time_change
from homeassistant.util.json import load_json, save_json
from homeassistant.util import dt as dt_util
SUPPORT_ALEXA = (SUPPORT_PAUSE | SUPPORT_PREVIOUS_TRACK |
SUPPORT_NEXT_TRACK | SUPPORT_STOP |
SUPPORT_VOLUME_SET | SUPPORT_PLAY |
SUPPORT_PLAY_MEDIA | SUPPORT_TURN_OFF |
SUPPORT_VOLUME_MUTE | SUPPORT_PAUSE |
_CONFIGURING = {}
_LOGGER = logging.getLogger(__name__)
REQUIREMENTS = ['beautifulsoup4==4.6.0']
MIN_TIME_BETWEEN_SCANS = timedelta(seconds=15)
MIN_TIME_BETWEEN_FORCED_SCANS = timedelta(seconds=1)
ALEXA_DATA = "alexa_media"
SERVICE_ALEXA_TTS = 'alexa_tts'
ATTR_MESSAGE = 'message'
ALEXA_TTS_SCHEMA = MEDIA_PLAYER_SCHEMA.extend({
vol.Required(ATTR_MESSAGE): cv.string,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_EMAIL): cv.string,
vol.Required(CONF_PASSWORD): cv.string,
vol.Required(CONF_URL): cv.string,
def request_configuration(hass, config, setup_platform_callback,
captcha_url=None):
"""Request configuration steps from the user."""
configurator = hass.components.configurator
async def configuration_callback(callback_data):
"""Handle the submitted configuration."""
def done():
configurator.request_done(instance)
hass.async_add_job(done)
hass.async_add_job(setup_platform_callback, callback_data)
instance = configurator.request_config(
"Alexa Media Player", configuration_callback,
description='Please enter the text for the above captcha.',
description_image=captcha_url,
submit_caption="Confirm",
fields=[{'id': 'captcha', 'name': 'Captca'}]
def setup_platform(hass, config, add_devices_callback,
discovery_info=None):
"""Set up the Alexa platform."""
if ALEXA_DATA not in hass.data:
hass.data[ALEXA_DATA] = {}
email = config.get(CONF_EMAIL)
password = config.get(CONF_PASSWORD)
url = config.get(CONF_URL)
login = AlexaLogin(url, email, password)
async def setup_platform_callback(callback_data):
login.login(captcha=callback_data.get('captcha'))
if 'login_successful' in login.status:
hass.async_add_job(setup_alexa, hass, config,
add_devices_callback, login)
else:
login.reset_login()
login.login()
hass.async_add_job(request_configuration, hass, config,
login.status['captcha_image_url'])
if 'captcha_required' in login.status:
def setup_alexa(hass, config, add_devices_callback, login_obj):
"""Set up a alexa api based on host parameter."""
alexa_clients = hass.data[ALEXA_DATA]
alexa_sessions = {}
track_utc_time_change(hass, lambda now: update_devices(), second=30)
@util.Throttle(MIN_TIME_BETWEEN_SCANS, MIN_TIME_BETWEEN_FORCED_SCANS)
def update_devices():
"""Update the devices objects."""
devices = AlexaAPI.get_devices(url, login_obj._session)
devices = devices.json()['devices']
bluetooth = AlexaAPI.get_bluetooth(url, login_obj._session).json()
new_alexa_clients = []
available_client_ids = []
for device in devices:
for b_state in bluetooth['bluetoothStates']:
if device['serialNumber'] == b_state['deviceSerialNumber']:
device['bluetooth_state'] = b_state
available_client_ids.append(device['serialNumber'])
if device['serialNumber'] not in alexa_clients:
new_client = AlexaClient(config, login_obj._session, device,
update_devices, url)
alexa_clients[device['serialNumber']] = new_client
new_alexa_clients.append(new_client)
else:
alexa_clients[device['serialNumber']].refresh(device)
if new_alexa_clients:
def tts_handler(call):
for alexa in service_to_entities(call):
if call.service == SERVICE_ALEXA_TTS:
message = call.data.get(ATTR_MESSAGE)
alexa.send_tts(message)
def service_to_entities(call):
"""Return the known devices that a service call mentions."""
entity_ids = extract_entity_ids(hass, call)
if entity_ids:
entities = [entity for entity in new_alexa_clients
if entity.entity_id in entity_ids]
else:
entities = rokus
return entities
hass.services.register(DOMAIN, SERVICE_ALEXA_TTS, tts_handler,
schema=ALEXA_TTS_SCHEMA)
add_devices_callback(new_alexa_clients)
update_devices()
class AlexaClient(MediaPlayerDevice):
"""Representation of a Alexa device."""
def __init__(self, config, session, device, update_devices, url):
"""Initialize the Alexa device."""
# Class info
self.alexa_api = AlexaAPI(self, session, url)
self.update_devices = update_devices
# Device info
self._device = None
self._device_name = None
self._device_serial_number = None
self._device_type = None
self._device_family = None
self._device_owner_customer_id = None
self._software_version = None
self._available = None
self._capabilities = []
# Media
self._session = None
self._media_duration = None
self._media_image_url = None
self._media_title = None
self._media_pos = None
self._media_album_name = None
self._media_artist = None
self._player_state = None
self._media_is_muted = None
self._media_vol_level = None
self._previous_volume = None
self._source = None
self._source_list = []
self.refresh(device)
def _clear_media_details(self):
"""Set all Media Items to None."""
# General
self._media_player_state = None
def refresh(self, device):
"""Refresh key device data."""
self._device = device
self._device_name = device['accountName']
self._device_family = device['deviceFamily']
self._device_type = device['deviceType']
self._device_serial_number = device['serialNumber']
self._device_owner_customer_id = device['deviceOwnerCustomerId']
self._software_version = device['softwareVersion']
self._available = device['online']
self._capabilities = device['capabilities']
self._bluetooth_state = device['bluetooth_state']
self._source = self._get_source()
self._source_list = self._get_source_list()
session = self.alexa_api.get_state().json()
self._clear_media_details()
# update the session
self._session = session
if 'playerInfo' in self._session:
self._session = self._session['playerInfo']
if self._session['state'] is not None:
self._media_player_state = self._session['state']
self._media_pos = self._session['progress']['mediaProgress']
self._media_is_muted = self._session['volume']['muted']
self._media_vol_level = self._session['volume']['volume'] / 100
self._media_title = self._session['infoText']['title']
self._media_artist = self._session['infoText']['subText1']
self._media_album_name = self._session['infoText']['subText2']
self._media_image_url = self._session['mainArt']['url']
self._media_duration = self._session['progress']['mediaLength']
@property
def source(self):
"""Return the current input source."""
return self._source
@property
def source_list(self):
"""List of available input sources."""
return self._source_list
def select_source(self, source):
"""Select input source."""
if source == 'Local Speaker':
self.alexa_api.disconnect_bluetooth()
self._source = 'Local Speaker'
elif self._bluetooth_state['pairedDeviceList'] is not None:
for devices in self._bluetooth_state['pairedDeviceList']:
if devices['friendlyName'] == source:
self.alexa_api.set_bluetooth(devices['address'])
self._source = source
def _get_source(self):
for device in self._bluetooth_state['pairedDeviceList']:
if device['connected'] == True:
return device['friendlyName']
return source
def _get_source_list(self):
sources = []
sources.append(devices['friendlyName'])
return ['Local Speaker'] + sources
@property
def available(self):
"""Return the availability of the client."""
return self._available
@property
def unique_id(self):
"""Return the id of this Alexa client."""
return self.device_serial_number
@property
def name(self):
"""Return the name of the device."""
return self._device_name
@property
def device_serial_number(self):
"""Return the machine identifier of the device."""
return self._device_serial_number
@property
def device(self):
"""Return the device, if any."""
return self._device
@property
def session(self):
"""Return the session, if any."""
return self._session
@property
def state(self):
"""Return the state of the device."""
if self._media_player_state == 'PLAYING':
return STATE_PLAYING
elif self._media_player_state == 'PAUSED':
return STATE_PAUSED
elif self._media_player_state == 'IDLE':
return STATE_IDLE
return STATE_STANDBY
def update(self):
"""Get the latest details."""
self.update_devices(no_throttle=True)
@property
def media_content_type(self):
"""Return the content type of current playing media."""
if self.state in [STATE_PLAYING, STATE_PAUSED]:
return MEDIA_TYPE_MUSIC
@property
def media_artist(self):
"""Return the artist of current playing media, music track only."""
return self._media_artist
@property
def media_album_name(self):
"""Return the album name of current playing media, music track only."""
return self._media_album_name
@property
def media_duration(self):
"""Return the duration of current playing media in seconds."""
return self._media_duration
@property
def media_image_url(self):
"""Return the image URL of current playing media."""
return self._media_image_url
@property
def media_title(self):
"""Return the title of current playing media."""
return self._media_title
@property
def device_family(self):
"""Return the make of the device (ex. Echo, Other)."""
return self._device_family
@property
def supported_features(self):
"""Flag media player features that are supported."""
return SUPPORT_ALEXA
def set_volume_level(self, volume):
"""Set volume level, range 0..1."""
if not (self.state in [STATE_PLAYING, STATE_PAUSED]
and self.available):
return
self.alexa_api.set_volume(volume)
self._media_vol_level = volume
@property
def volume_level(self):
"""Return the volume level of the client (0..1)."""
return self._media_vol_level
@property
def is_volume_muted(self):
"""Return boolean if volume is currently muted."""
if self.volume_level == 0:
return True
return False
def mute_volume(self, mute):
"""Mute the volume.
Since we can't actually mute, we'll:
- On mute, store volume and set volume to 0
- On unmute, set volume to previously stored volume
if not (self.state == STATE_PLAYING and self.available):
return
self._media_is_muted = mute
if mute:
self._previous_volume = self.volume_level
self.alexa_api.set_volume(0)
else:
if self._previous_volume is not None:
self.alexa_api.set_volume(self._previous_volume)
else:
self.alexa_api.set_volume(50)
def media_play(self):
"""Send play command."""
return
self.alexa_api.play()
def media_pause(self):
"""Send pause command."""
return
self.alexa_api.pause()
def turn_off(self):
"""Turn the client off."""
# Fake it since we can't turn the client off
self.media_pause()
def media_next_track(self):
"""Send next track command."""
return
self.alexa_api.next()
def media_previous_track(self):
"""Send previous track command."""
return
self.alexa_api.previous()
def send_tts(self, message):
"""Send TTS to Device NOTE: Does not work on WHA Groups"""
self.alexa_api.send_tts(message)
def play_media(self, media_type, media_id, **kwargs):
"""Send the play_media command to the media player."""
if media_type == "music":
self.alexa_api.send_tts("Sorry, text to speech can only be called " +
" with the media player alexa tts service")
else:
self.alexa_api.play_music(media_type, media_id)
@property
def device_state_attributes(self):
"""Return the scene state attributes."""
attr = {
'available': self._available,
return attr
class AlexaLogin():
def __init__(self, url, email, password):
self._url = url
self._email = email
self._password = password
self._data = None
self.status = None
self.login()
def reset_login(self):
self._data = None
self.status = None
def get_inputs(self, soup):
data = {}
form = soup.find('form', {'name': 'signIn'})
for field in form.find_all('input'):
try:
data[field['name']] = field['value']
except:
pass
return data
def login(self, cookies=None, captcha=None):
if self._session is None:
site = 'https://www.' + self._url + '/gp/sign-in.html'
'''initiate session'''
self._session = requests.Session()
'''define session headers'''
self._session.headers = {
'User-Agent': 'Mozilla/5.0 (Windows NT 6.3; Win64; x64) \
AppleWebKit/537.36 (KHTML, like Gecko) \
Chrome/44.0.2403.61 Safari/537.36',
'Accept': 'text/html,application/xhtml+xml, \
application/xml;q=0.9,*/*;q=0.8',
'Accept-Language': 'en-US,en;q=0.5',
'Referer': site
if self._data is None:
resp = self._session.get(site)
html = resp.text
'''get BeautifulSoup object of the html of the login page'''
soup = BeautifulSoup(html , 'lxml')
'''scrape login page to get all the needed inputs required for login'''
self._data = self.get_inputs(soup)
status = {}
'''add username and password to the data for post request'''
self._data[u'email'] = self._email
self._data[u'password'] = self._password
if captcha is not None:
self._data[u'guess'] = captcha
'''submit post request with username/password and other needed info'''
post_resp = self._session.post('https://www.' + self._url +
'/ap/signin', data = self._data)
post_soup = BeautifulSoup(post_resp.content , 'lxml')
captcha_tag = post_soup.find(id="auth-captcha-image")
if captcha_tag is not None:
status['captcha_required'] = True
status['captcha_image_url'] = captcha_tag.get('src')
self._data = self.get_inputs(post_soup)
else:
'''attempt to get device list, if unsuccessful login failed'''
post_resp = self._session.get('https://alexa.' + self._url +
'/api/devices-v2/device')
if 'devices' in post_resp.text:
status['login_successful'] = True
else:
status['login_failed'] = True
self.status = status
class AlexaAPI():
def __init__(self, device, session, url):
self._url = 'https://alexa.' + url
csrf = self._session.cookies.get_dict()['csrf']
self._session.headers['csrf'] = csrf
def _post_request(self, uri, data):
try:
self._session.post(self._url + uri, json = data)
except:
_LOGGER.error("An error occured accessing the API")
def _get_request(self, uri, data=None):
try:
return self._session.get(self._url + uri, json = data)
except:
return None
def play_music(self, provider_id, search_phrase):
data = {
"behaviorId":"PREVIEW",
"sequenceJson":"{\"@type\": \
\"com.amazon.alexa.behaviors.model.Sequence\", \
\"startNode\":{\"@type\": \
\"com.amazon.alexa.behaviors.model.OpaquePayloadOperationNode\", \
\"type\":\"Alexa.Music.PlaySearchPhrase\",\"operationPayload\": \
{\"deviceType\":\"" + self._device._device_type + "\", \
\"deviceSerialNumber\":\"" + self._device.unique_id +
"\",\"locale\":\"en-US\", \
\"customerId\":\"" + self._device._device_owner_customer_id +
"\", \"searchPhrase\": \"" + search_phrase + "\", \
\"sanitizedSearchPhrase\": \"" + search_phrase + "\", \
\"musicProviderId\": \"" + provider_id + "\"}}}",
"status":"ENABLED"
self._post_request('/api/behaviors/preview',
data=data)
data = {
\"type\":\"Alexa.Speak\",\"operationPayload\": \
"\", \"textToSpeak\": \"" + message + "\"}}}",
"status":"ENABLED"
data=data)
def set_media(self, data):
self._post_request('/api/np/command?deviceSerialNumber=' +
self._device.unique_id + '&deviceType=' +
self._device._device_type, data=data)
def previous(self):
self.set_media({"type": "PreviousCommand"})
def next(self):
self.set_media({"type": "NextCommand"})
def pause(self):
self.set_media({"type": "PauseCommand"})
def play(self):
self.set_media({"type": "PlayCommand"})
def set_volume(self, volume):
self.set_media({"type":"VolumeLevelCommand",
"volumeLevel": volume*100})
def get_state(self):
response = self._get_request('/api/np/player?deviceSerialNumber=' +
self._device._device_type + '&screenWidth=2560')
return response
@staticmethod
def get_bluetooth(url, session):
try:
response = session.get('https://alexa.' + url +
'/api/bluetooth?cached=false')
return response
except:
return None
def set_bluetooth(self, mac):
self._post_request('/api/bluetooth/pair-sink/' +
self._device._device_type + '/' +
self._device.unique_id,
data={"bluetoothDeviceAddress": mac})
def disconnect_bluetooth(self):
self._post_request('/api/bluetooth/disconnect-sink/' +
self._device.unique_id, data=None)
@staticmethod
def get_devices(url, session):
try:
return response
except:
return None
In my config.yaml
media_player:
- platform: mpd
arguments: 'alsa-audio-device=hw:0,0'
host: 192.168.86.238
port: 6600
- platform: alexa
email: [email protected]
password: Mypassword
url: amazon.com
Am I missing anything? Thanks for getting this out there, I cant wait to see it work!
You have any errors in your “info” area? like “ImportError: No module named ‘bs4’”
if so you need BeautifulSoup installed and I dont think you can do that with Hassio.
School boy error for a man of your calibre!
i don’t see any I’m actually running hassos, maybe thats it?)
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
pip3 install bs4
pip install lxml
if i put this:
I get:
su: unknown user homeassistant
Am i doing something wrong, im not too familiar with terminal
this one did work
pip3 install bs4
How did you install bs4 on hassos? I try and it says
-bash: pip3: command not found
im not sure, but I entered the command and it worked. sucessfully installed beautifulsoup4-4.6.1 bs4-0.0.01
but still no media player
I swear it sometimes takes multiple restarts to work. I had issues with it today and after the 3rd restart (and captcha) it worked. shrug I dunno
i have restarted at-least 6/7 times.
in my log the only reference to alexa is
[homeassistant.loader] You are using a custom component for media_player.alexa which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
actually im getting the captca but no image is there, so I cant configure it. Im almost there
Error doing job: Future exception was never retrieved
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/media_player/alexa.py”, line 174, in setup_alexa
update_devices()
File “/usr/local/lib/python3.6/site-packages/homeassistant/util/init.py”, line 318, in wrapper
result = method(*args, **kwargs)
File “/config/custom_components/media_player/alexa.py”, line 130, in update_devices
devices = devices.json()[‘devices’]
File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 896, in json
return complexjson.loads(self.text, **kwargs)
File “/usr/local/lib/python3.6/site-packages/simplejson/init.py”, line 518, in loads
return _default_decoder.decode(s)
File “/usr/local/lib/python3.6/site-packages/simplejson/decoder.py”, line 370, in decode
obj, end = self.raw_decode(s)
File “/usr/local/lib/python3.6/site-packages/simplejson/decoder.py”, line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 8 column 1 (char 7)
Here are 2 examples, which work flawlessly (one automation, and one script), and you can go from there:
1. The automation
Description: It reads some sensor values out loud, on one specific Echo device (which is the one you put in the entity_id
: field, note that you can put multiple devices there, separated by comma) … feel free to adjust to your needs … here it is
- id: tts_over_alexa_devices
alias: 'Send TTS message to Alexa device of your choice'
- platform: state
entity_id: input_boolean.test_button_1
to: 'on'
condition:
- condition: and
conditions:
- condition: state
state: 'on'
# ============= ALEXA named BATMAN, location = Livingroom / Sufragerie
- service: media_player.alexa_tts
data_template:
entity_id: media_player.batman
## message: “Michael ? ... This message will selfdestruct in 5 ... 4 ... 3 ... ha ha ha, gotcha ! ... welcome ! home !”
message: “ Hello! Michael, this is your climate and weather report, The outside temperature is {{states ('sensor.dark_sky_apparent_temperature') }} degrees, the home climate system states the following values for Livingroom, {{states.climate.sufragerie.attributes.current_temperature}}, Bedroom, {{states.climate.dormitor.attributes.current_temperature}}, and Kitchen, {{states.climate.bucatarie.attributes.current_temperature}} ”
2. The script
Description: This script is called upon by an automation. The automation fires up multiple scripts which turn on my air conditioning unit, sets it to 25°C, sets the fan to quiet mode and lastly sends the command to shut down after 1 hour … all through my Harmony Hub, then, at the end, some Echo devices announce the event in a few places of my home (note: presented here, is just the “alexa” script):
# ALEXA says: Living room air conditioning unit, is set for 25 degrees for one hour!
tts_alexa_lg_ac_on_25_sleep_1hr_call:
alias: "ALEXA say: Living room air conditioning unit, is set for 25 degrees for one hour!, call"
sequence:
# Cancel "execute" script, in case it has timers, to reset them
- service: script.turn_off
entity_id: script.tts_alexa_lg_ac_on_25_sleep_1hr_execute
# Call "execute" script into action again
- service: script.turn_on
tts_alexa_lg_ac_on_25_sleep_1hr_execute:
alias: "Alexa say: Living room air conditioning unit, is set for 25 degrees for one hour!, execute"
sequence:
data_template:
entity_id: media_player.batman, media_player.spiderman, media_player.ironman
message: “ Living room air conditioning unit, is set for 25 degrees for one hour! ”
Note:
For every automation that calls a script, in my setup I have 2 scripts, this is for best practice:
- The first script, Script No.1, is called: name_of_the_script_call
- The second script, Script No.2, is called: name_of_the_script_execute
- Script Nr.1 turns off any instances of Script Nr.2 that may be running, then turns it back on (usefull if you have delays or timers in your scripts), otherwise if you call the same script again (lets say the automation fired again but the script did not finished its sequence), the timers will overlap or be fired again when there is no need for that … again, I repeat, … best pactice.
My automations always call for Script No.1, the one with the _call in its name, and in turn, that script calls for Script No. 2, the one with the _execute in its name.
Hope it helps.
Even with debug enabled I just get:
2018-08-03 09:26:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/config/custom_components/media_player/alexa.py", line 98, in setup_platform_callback
File "/config/custom_components/media_player/alexa.py", line 557, in login
post_resp_json = post_resp.json()['devices']
File "/usr/local/lib/python3.6/site-packages/requests/models.py", line 896, in json
File "/usr/local/lib/python3.6/site-packages/simplejson/__init__.py", line 518, in loads
File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py", line 370, in decode
File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py", line 400, in raw_decode
I would like to use your debug version but I am not sure where the issue is in using the /tmp directory to save the HTML responses. In the docker instance of homeassistant a /tmp exists???
Regards
Has anybody else had this happen?
I did get a image finally last night using Firefox but put the wrong numbers in because it was hard to read so I restarted a few times and still had a bad image (but still tried to put the correct letters/numbers) then after resetting again the image went away and this is all I see from any browser. I just wondered if there was a work around or suggestions that might help.
I’m running HA 74.2 on ubuntu 16.04, in a venv.
Using firefox, I get a captcha, Sometimes i enter it and it goes away, like I did it right, but the media devices dont add.
Restart HA, try again.
Sometimes I enter the captcha, and then get promted again, but this time with a blank screen. (I suspect that i entered the captcha wrong in these cases (or at least my resonse was not received correctly), and that its trying to display a second captcha but fails
restart HA again.
Usually after 3 or 4 tries it works, until I restart HA the next time, and then I start over again.
Not complaining, just sharing my experience.
Also I never installed any version of this until about a week ago.
TBH I was never able to get any of my devices discovered let alone even have the captcha appear using the later method (without addon)
So the only thing that works for me is replacing the current 0.7.x alexa.py version with the 0.5 version together with the addon and config.yaml all setup.
Works in Australia, but I have my account location set to US
