Restart mate. Or reboot.
Try the capture a few times, dosnt always work first time for me
But you have to do the capture every time you restart at the moment
And it needs to be done just after restart or it dosnt take effect
You can press “CONFIRM” for the first time. After that, it will show captca.
Too true. Very embarrassed when I figured out what it was…
Running latest HA (Ubuntu 16.04, python 3.6 running in a venv)
I only got my echos to show up once a few days ago, but I’ve only been playing with this for a few days.
after a restart or two, I am able to get the captcha to seem to be accepted, but no media players for my echos appear.
Here is my errors in the log
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/home/homeassistant/.homeassistant/custom_components/media_player/alexa.py", line 120, in <lambda>
track_utc_time_change(hass, lambda now: update_devices(), second=30)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 325, in wrapper
result = method(*args, **kwargs)
File "/home/homeassistant/.homeassistant/custom_components/media_player/alexa.py", line 129, in update_devices
devices = devices.json()['devices']
File "/srv/homeassistant/lib/python3.6/site-packages/requests/models.py", line 896, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/lib/python3.6/json/__init__.py", line 354, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.6/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.6/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 8 column 1 (char 7)
I appologize if I’m asking repeat questions that other may have asked, but most of the recent comments seem to be dealing with hass.io, and i know the process is not exactly the same.
Thanks!
im getting the same error on Hassos
still the same code, ill keep trying thanks for the tip!
Today I finally got that error you and others keep getting annoyed by …
It seems that something “on the Amazon side of things” had happened overnight, around 2:30AM … and the dev-log was spammed with “the error”, every few minutes or so, until this morning when I saw it.
I fired up my “test automation”, which reports some values from temp. & climate sensors and my Echo just stood there, silent …
AHA !, I finally got “the virus” everyone is talking about ! … you know , the one ending with
So, as you well know, I went on to open https://www.amazon.com and proceed with some sign-out, sign-in sequences, followed by a HA restart. HA restarted, captcha appeared, got it from first try (that’s a win) and fired up the automation again … still no sound.
Oh crap … so that’s how @gregbert feels … ok, back to amazon.
By trial and error, this is what I did, then restarted and everything is working, again.
Went to amazon site
I was presented again, with this:
Pressed Continue button
Like never before, the Chrome tab flashed a bit, like a blink, did not log in and in the upper corner was this:
And the login screen got a little “add-on” (marked here in red)
Went on and added amazon domain to flash allowed, in chrome settings:
Checked that keep me signed in check-box, and signed in again.
Once signed in, I clicked the “switch accounts” link and signed out of there also, signed in again
I know it’s alot but … Restarted HA, the captcha appeared by itself in the middle of the screen, picture and everything (that’s a first) … until now, I had to click the configure button, but not this one time … anyway, I got past the captcha, and ran the test automation.
The Echo went live (came back to life) and Alexa’s voice filled the room once again …
How long until I get the error again ?, I don’t know, (I switched to HA 0.75 last night), I’ll keep you posted.
Have a nice weekend @gregbert.
Is this an automation or something else setup in your echo?
Hi, sorry for the miss understanding I might have caused. The Echo’es are always “live”.
But in that context, you guessed it, it went “live” (figure of speach), as an effect of an automation … which meant for me that HA and alexa_tts
component somehow got together again.
This automation (which is triggered by an input_boolean):
- id: tts_over_alexa_devices
alias: 'Send TTS message to Alexa device of your choice'
- platform: state
entity_id: input_boolean.test_button_1
to: 'on'
condition:
- condition: and
conditions:
- condition: state
state: 'on'
# = Echo device = BATMAN = Livingroom/Sufragerie
- service: media_player.alexa_tts
data_template:
entity_id: media_player.batman
message: “ Hello Michael !, this is your climate and weather report, The outside temperature is {{states ('sensor.dark_sky_apparent_temperature') }} degrees, the home climate system states the following values for Livingroom, {{states.climate.sufragerie.attributes.current_temperature}}, Bedroom, {{states.climate.dormitor.attributes.current_temperature}}, and Kitchen, {{states.climate.bucatarie.attributes.current_temperature}} ”
@keatontaylor @davidlamd89 @goliath_2k @xx_Nexus_xx @planet4
Hey y’all - if you’re still having problems removing the addon, here are the steps that worked for me. Note that the addon still shows somehow in the hassio panel (twice, actually), but these are safe to ignore. The custom_component
by @keatontaylor now works just find and dandy. Thanks again to @keatontaylor for this!
First, enable debugging access to ResinOS. Instructions from the docs are here, but the steps are this:
id_rsa.pub
file to authorized_keys
without any extension. Usually this means that you’ll have to use your terminal. On mac, it’d be: mv .ssh/id_rsa.pub authorized_keys
authorized_keys
file to the main directory of the SD card…ssh root@IPADDRESS -p 22222
ls
and you’ll see the resin-data
directory.cd resin-data
ha
. Open another terminal window, and ssh into the docker machine: ssh root@IPADDRESS
and enter the command: hassio ha stop
vi
. Edit addons.json with vi by vi addons.json
dd
for each line. Make sure to retain JSON formatting for the stuffs you aren’t deleting.ESC
then :
then wq
then hit ENTER
Ok. We’re probably good now, but I went a bit further. There’s a few directories and files to clear out too.
addons
by typing cd addons
ls
you’ll see four directories: core, data, git, and localrm -r FILE_OR_DIRECTORY
Bam. Now restart ha
and move on with the life.
This worked for me. I hope this helps someone. Not sure why the addon still shows in HA, but whatever. I don’t much care. I’ve got alexa_tts and media control again thanks to @keatontaylor.
Spot on BRO!!! Thanks so much!
I did put this into my browser: chrome://settings/content
And it brought up the flash settings, I added www.amazon.com to the allow list and restarted my HA, Thats when the magic happened and I heard her wonderful voice!
Thanks for sharing your workaround!
I’m happy to see you managed to get it working again too.
This is a beautiful component and its full potential is yet to come.
Glad I could help. Have a nice weekend @Corey_Maxim …
You Too! I absolutely love this!!!
Can services be mixed?
I have a custom greeting, that I was wondering if it would work? Or if these a better way to format it.
script.yaml
say_greeting:
sequence:
service:
- media_player.alexa_tts
- tts.google_say
data_template:
entity_id: "{{ entity_id }}"
message: "{{ message.replace('PERSON',person) }}"
automation.yaml
- id: family_greeting
alias: Family Greeting
platform: state
entity_id:
- binary_sensor.cameron_home
- binary_sensor.corey_home
- binary_sensor.courtney_home
- binary_sensor.mom_home
- binary_sensor.morgan_home
- binary_sensor.wendy_home
- binary_sensor.andy_home
- binary_sensor.jasmine_home
- binary_sensor.brandon_home
to: 'on'
for: '00:00:05'
- wait_template: "{{ is_state('script.say_greeting', 'off') }}"
- service: script.say_greeting
data_template:
entity_id:
- "media_player.livingroom,media_player.bedroom,media_player.courtneys_room"
- media_player.fire_speaker
person: >
{{ trigger.to_state.name }}
{%- for s in states.binary_sensor
|rejectattr('entity_id','eq',trigger.entity_id)
|selectattr('state','eq','on')
if '_home' in s.entity_id and
(now() - s.last_changed).total_seconds() < 60 -%}
{{ (' and ' if loop.last else ', ') ~ s.name }}
{%- endfor %}
message: >
{{ ["Welcome back home PERSON",
"Guess who is home PERSON is!",
"PERSON is now in the house.",
"Welcome Home PERSON We have missed you Or at least I did.",
"Attention Everybody PERSON is home I repeat PERSON is home Welcome home PERSON",
"Our home is now complete, Rest your head and relax your feet, Welcome Back PERSON",
"Life is like a song, you’re back where you belong, Welcome home PERSON",
"Hey there PERSON Welcome Home!",
"Knock Knock. Who is There? PERSON is!",
"PERSON, you are home!",
"I know a secret. PERSON is home!",
"PERSON it's nice to see you again. Right where you belong. Welcome home PERSON",
"O M G it's PERSON. Oh how I missed your face. Welcome home",
"Welcome back to the best house in th 3 3 0 PERSON",
"Oh Goodie PERSON is home. Welcome back",
"When PERSON is here we are complete. Its nice to see you PERSON"
"Its not the same when PERSON isn't here, so from the MAXIM's welcome home"
] | random }}
I’ve updated the PR that is pending to fix the JSON Decode bug.
It adds:
Wow looks awesome,thanks for your hard work! One question, i am running hassio on a ubuntu server 18.4 VM on windows 10. Will it work, should i do anything different? Thanks for the help.
Installed this a few weeks ago and now I cannot uninstall “Alexa Media Player API” . Anyone have any idea how I can clean this up?
Scroll up a few posts. I’ve provided instructions for uninstalling the addon
Could you maybe walk a noob through how and where to enter this and set it up. I have everything else working but cant wrap my head around the tts part and that is what i want the most.
I am running hassio on a ubuntu server 18.4 vm under windows 10 home. Thanks for your help if you can find the time!
