Echo Devices (Alexa) as Media Player - Testers Needed
Can we get any data at all from devices added to alexa directly?? I was under the impression that amazon did not allow this, so I moved all my devices to HA. Just curious as too my options.
You usually can set/override an entity’s device class using YAML homeassistant: customize:
Same here!
  1. Is there a way to know when a echo device has completed a TTS message using homeassistant?
  2. Amazon plugs are not getting integrated. How to integrate Amazon plugs?
  3. Songs from AMAZON_MUSIC is not playing if linked to an Indian account. Is there a way to play songs from AMAZON_MUSIC while staying with Indian account?
Kindly help
  1. no, not as far as i know. but if you use announcement the next command is done after the announcement.
  2. amazon plugs are normally zigbee or wifi, so automate/intergrate them in another way not through amazon.
  3. i got not clue what an indian account is. i think you can only play amazon music on amazon devices, devices connected to amazon devices or devices that have an amazon app.
  1. I tried… the next action is executed while alexa is still announcing… any way to check is previous action/command has finished.
  2. Any guidance or tutorial on how to do this?
  3. If I switch to Amazon US. I can send command to play music thru HA on my echo devices, and the music selection is done from amazon_music. But if I change the location to india fromm amazon account. Then I am not able to send commands to play music from HA
  1. no, because amazon doesnt send a message when the announcement is finished. if you send 2 announcements they will come after each other, but if you send an announcement and want a light to turn on AFTER that, then there is no way. youll need to calculate the time yourself.
  2. depends on what type of plugs you got. if they are zigbee then youll need another zigbee hub or zigbee coordinator and then use zigbee2mqtt or zha. if they are wifi youll need to check the integration for that brand in HA.
  3. you will need to connect both amazon accounts with HA, to be able to send commands to both accounts. personally i think its best just to use only 1 account with amazon if you want to automate.
  1. Yes… using a delay in between.
  2. This is the plug. The plug is from Amazon only. (Amazon Smart Plug, for home automation, Works with Alexa- A Certified for Humans Device https://www.amazon.com/dp/B089DR29T6/ref=cm_sw_r_awdo_RM906EDNTPN0N4BWPCXF)
Any idea how to add this to HA.
  1. Got it…
Thanks a lot for the clarifications.
The made for Alexa plugs can’t really be integrated directly into Home Assistant:
Thanks a lot for links… really appreciate it.
i didnt even know that existed. but thats wifi and you are depending on the control from the brand, so in this case amazon, who doesnt release its api yet.
i would integrate it the same way as in the second link digeridew gave you.
Yes… really thanks a lot for your support
Hi, from time to time since a few weeks I receive this error:
Logger: homeassistant.components.alexa.state_report
Source: components/alexa/state_report.py:179
Integration: Amazon Alexa (documentation, issues)
First occurred: 6. Mai 2022, 21:28:20 (3 occurrences)
Last logged: 6. Mai 2022, 21:28:20
Error when sending ChangeReport for light.wohnzimmer to Alexa: THROTTLING_EXCEPTION: Request could not be processed due to throttling.
Everything works fine. At least I cannot notice any strange behavior.
Can somebody explain what that is?
It’s not related to this custom component.
OK, then it comes from the cloud integration. Thanks
hello,
is it not possible to listen to the “ResponseNone” Event?
i tried it with this code
platform: event
event_type: alexa_actionable_notification
event_data:
  event_id: actionable_notification_firetv_kueche_switch_off
  event_response_type: ResponseNone
but the automation get never triggered when alexa get no answer from me.
here is the automation for the question
service: script.activate_alexa_actionable_notification
data_template:
  text: Hallo, Soll ich die Shield ausschalten?
  alexa_device: media_player.echo_show_kueche
and in the script is everything correct, the ResponseYes works well.
This isn’t the right thread for this discussion. Try Actionable Notifications via Alexa Media Player - #256 by dbrunt
Please post your question and the entire automation(s) and script(s) over in Actionable Notifications via Alexa Media Player - #256 by dbrunt
Will this work on locally stored MP3? I tried it but no success. I replaced the URL to the local full file path but it did not work.
Amazon has set very specific limits on bitrate and length so you need to make sure your file is properly formatted and isn’t too long. One of the best resources on this topic is Mark Watt’s video: Play a local mp3 file on Alexa Echo dot - #33 by MarkWattTech
