I’m having setup issues.
I’ve set MFA for the config app as described, however the Amazon MFA page says to click “time based” in the app setup.
I don’t see that on the HA config for the integration.
When I complete the setup and go to the next screen, it tries to log me in to Alexa however the MFA token that is generated looks to be a static one and not time based (this is my assumption) because I am getting this error:
There was a problem
The One Time Password (OTP) you entered is not valid. Please try again.
I have a nightmare with HACS components since the latest upgrade but nothing (thankfully) with AMP
My errors are with lovelace components and I have a consistent error with HACS
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/connection.py:96
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 20:15:31 (9 occurrences)
Last logged: 20:15:31
[547876251344] Received invalid command: hacs/subscribe
But after re-downloading the components everything works!!
Still get the above error though which has occurred since updating HACS
@agratam Would you mind outlining how you changed the domain. One the config is set up it does not allow you to alter any settings. Currently there are no entries in the configuration.yaml for it.
It’s not in yaml but though integrations
When you add Alexa media player integration you can pick the region domain. It has to be the same where your echo devices are registered.
Remove and readd the integration to change settings. Everything should stay consistent between installs as long as your Echo serial numbers don’t change for some reason.
After the recent update to Alexa Media integration (Hacs) , I keep getting notification after reboot of my raspberry pi for “Alexa Media Reauthentication required”
I reauthenticate it… until the next reboot everything works fine and after a reboot of raspberry pi the same notification comes.
Yes, I am experiencing the same thing. I think it’s maybe something to do with the 2022.6 update. I am on alexa_media_player 4.0.1 and 2022.5.5 with no issue after any restart of HA. No reauthentication required.
After I update to 2022.6 but still on alexa media player 4.0.1, I was getting the reauthentication message after every restart of HA. I’ve updated to 4.0.2, and still getting the same message as well.
I am seeing this error in log.
Logger: alexapy.alexalogin
Source: /usr/local/lib/python3.9/site-packages/alexapy/alexalogin.py:706
First occurred: 4:19:38 PM (1 occurrences)
Last logged: 4:19:38 PM
No access token found; falling back to credential login instead of oauth.
Logger: custom_components.alexa_media
Source: helpers/update_coordinator.py:223
Integration: Alexa Media Player (documentation, issues)
First occurred: 4:19:47 PM (1 occurrences)
Last logged: 4:19:47 PM
Error fetching alexa_media data: Error communicating with API:
I converted all my “legacy groups” to the new helper groups. I’m having a hard time getting my media_player groups (of echo devices) to work with the alexa notify. Send “hello” to all the downstairs echos. Do helper groups work? Do I need to specify each echo device on the service call?
Can’t find “next_timer” attributes in my alexa device. I’ve just set a timer on the device. In the attached screenshot, you can see my “last_called_summary” as “alexa set a timer for thirty five minutes”. I’m expecting to find a “next_timer” attribute, but it’s not there.
I’m not using “alexa” at all in my /config/configuration.yaml (see screenshot). Any ideas ?
