I have this integration installed and configured in my HA.
I have devices from HA discovered and working fine in Alexa - or so I thought.
Recently I have added a Sonoff ZigBee stick to HA and a few ZigBee devices using zigbee2mqtt (not the integrated HA one - I have it running on a separate server). All zigbee devices added work fine in HA - can see them can control them etc
Zigbee2mqtt works fine as I have devices discovered in my Alexa account like Tasmota, OpenBKN etc
However I can not Alexa to discover the zigbee devices . I do a discovery and is not seeing any ZigBee devices I have.
I am not sure what I am doing wrong here. I think Alexa is supposed to discover HA devices regardless if they are Tasmota, OpenBKN, ZigBee?
Any help to get the ZigBee devices in Alexa will be appreciated.
The Alexa Media Player custom integration, which is the subject of this thread, exposes Alexa devices to Home Assistant, it does not expose HA devices to Alexa. That functionality is covered by either HA Cloud, a custom Alexa skill, or NodeRed.
Have a really strange scenario where volume controls are working. Pause works but not play.
Cannot see if a device is playing music or not. Only update is at restart then if playing or if timer set all show.
Deleted my pickle as per FAQ but now there is no new one being generated. Everything says connected just no updates after start up. Can anyone suggest where to look next?
Hi all, Anyone else having problems with TTS notifications lately?
TTS worked fine for me for a long time, and the integration still appears to work (I can change volume on devices, etc), but for the last few months TTS notifications don’t work.
This has always worked before, but now I get some variation of the following error:
[homeassistant.components.websocket_api.http.connection] [140576097707216] Error handling message: expected a dictionary for dictionary value @ data['sequence'][0]['target']. Got ['media_player.alexa_living_room']
or
extra keys not allowed @ data['sequence'][0]['message']. Got 'test' (invalid_format) Sean Straus from [redacted IP] (Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:109.0) Gecko/20100101 Firefox/115.0)
This even happens when I just use the example from the docs as such:
service: notify.alexa_media
message: test
type: tts
- media_player.alexa_living_room
If they have a skill, use that. Otherwise, it’s a total crap shoot.
It looks like Sky Radio is available (at least in the US. YMMV) through the Dutch Radio skill. So you can add the skill to Alexa then use the custom commands feature or routines feature of AMP to play the station.
Yes, I have seen the Dutch radio skill, but it is way more complicated than (as you already pointed out) Google. I mostly use Chromecast to cast, so I can live without casting to Alexa, though it would have been nice to have it as an (easy) option. THANKS
you dont need specific radio skills.
tunein has hundreds of radio stations, including dutch local radio (like radio rijnmond) and german radio (like swr3), but also sky radio.
if you got tunein you can just say to alexa: “play radio rijnmond”.
a command through the media player automations would then be the same.
Thanks but that does not work. As an example when I ask Alexa to play Sky Radio I do not get the Dutch Sky Radio. I also tried Sky Radio 101, 101.5, Amsterdam…but still get a totally different Sky Radio. Maybe it is because I am in the US and maybe it works when in the Netherlands.
could very well be that that is in more countries.
i listened to it ages ago, so a year ago or so i tried it on tunein and got a russian radio called sky radio.
lucky for me that my wife hears all kind of radio that is available on tunein
i guess being in the USA, is just as difficult as being in germany when it goes for dutch things.
and talking dutch to alexa probably never will happen.
