I have been having the same issue… The entities just go in to the unavailable state after some time… After some time they come online randomly…
2024-01-28 09:10:57.209 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-28 09:10:57.211 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-28 09:11:13.326 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 233, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 149, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 50, in get
return await WebSocketHandler(request.app["hass"], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 275, in async_handle
await wsock.prepare(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_ws.py", line 153, in prepare
payload_writer = await super().prepare(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_response.py", line 415, in prepare
return await self._start(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_response.py", line 423, in _start
await self._write_headers()
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_response.py", line 503, in _write_headers
await writer.write_headers(status_line, self._headers)
File "/usr/local/lib/python3.11/site-packages/aiohttp/http_writer.py", line 130, in write_headers
self._write(buf)
File "/usr/local/lib/python3.11/site-packages/aiohttp/http_writer.py", line 75, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2024-01-28 09:11:39.188 ERROR (MainThread) [alexapy.alexaapi] Giving up _static_request(...) after 5 tries (alexapy.errors.AlexapyTooManyRequestsError: Too Many Requests)
2024-01-28 09:11:39.188 WARNING (MainThread) [alexapy.helpers] alexaapi.get_customer_history_records((<alexapy.alexalogin.AlexaLogin object at 0xffff82751310>,), {'max_record_size': 10}): An error occurred accessing AlexaAPI: An exception of type AlexapyTooManyRequestsError occurred. Arguments:
('Too Many Requests',)
2024-01-28 09:11:39.189 WARNING (MainThread) [alexapy.helpers] alexaapi.get_last_device_serial((<alexapy.alexalogin.AlexaLogin object at 0xffff82751310>,), {}): An error occurred accessing AlexaAPI: An exception of type AlexapyTooManyRequestsError occurred. Arguments:
2024-01-28 09:11:39.189 ERROR (MainThread) [custom_components.alexa_media] Error fetching alexa_media data: Error communicating with API: Too Many Requests
2024-01-28 09:11:39.303 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [Network unreachable]
2024-01-28 09:11:43.193 ERROR (MainThread) [custom_components.hacs] <QueueManager> <Plugin ljmerza/tracking-number-card> Repository structure for 3.0.4 is not compliant
