Stumbled my way through this forum. Finally got the captcha working on the main page. First time I try to use it, I dont get a picture, like some earlier in here. I just put some answer down and second try usually gets a captcha to see.
Now, after multiple time of trying, i cant seem to get past that.
storing it in secrets doesnt change anything.
thats still a plain text file.
the only difference it that you can share your configuration without modifying it.
if you never share your config the secrets file is rather useless.
but your config should not be exposed in any way normally. the plain text risk comes only up when you start reading your configfile outside your own network, or when you open up your network so that the file can be reached.
Forgot to mention, that I already use the secrets.yaml file. Nonetheless: a hacked Home Assistant setup would disclose your amazon password. @ReneTode was faster
I have the same problem. Had this running for months and one day got the captcha back and have since been in the dreaded endless captcha loop. I gave up on it and removed it from config file and periodically check the forum for an update as that fixed it for me once.
A solution would be very much appreciated as I miss the add on greatly, also many of my scripts and automations just don’t work without it.
Hello, I use this for a few things - dinner time announcement and doors left open, and haven’t noticed any trouble with it. However my logs are filled with warnings. I ignore them - expected?
Update of media_player.living_room_dot is taking over 10 seconds
Feeling really stupid about now. I have been trying to get this to work for a couple of hours and I get no response of any sorts from HASSIO that even resembles that I have added anything. I created the alexa.py file in the media_folder and copied the version 0.9.5 information into that file then added the media_player information into the configuration file without using quotes. Got no errors but also have no Alexa still. Am I missing something pretty obvious?
What version of the file are you using? The message you’re getting is from an older version before we made substantial improvements to the configuration. The latest version is VERSION 0.9.5.
@lessmann
Please make sure the alexa_media.pickle is deleted. If you enable debugging logs for alexa_media_player it should give you more information on where your login fails. It probably is a 2 factor authentication issue. If you do pull logs, you can message me directly with a private gist to store your logs (scrub password/email) and I can try to help.
One more question mate, what part of the flow sets what you can ask Alexa? Meaning the “Is the garage door open?” question. Or is that defined somewhere else? Cheers.
