Thanks Guys but
media_player:
- platform: alexa
email: “[email protected]”
password: “my.password”
url: “alexa.amazon.co.uk”
Still does not work
Thanks Guys but
media_player:
- platform: alexa
Still does not work
You still are using the incorrect quotation marks. Either use " quotation marks (they do not curl) or remove them.
Oh sorry I thought your comment was in relation to the incorrectly formatted response form mistrovly!
Will remove quotes and try again.
I only have " ’ as quotes on my mac
if you use a text only editor it should automatically use the correct quotation marks by default. If you use a rich text editor then you don’t know which you will get.
Hello everyone, so i’ve been using this addon for almost a month and everything was working fine until i updated to the latest version. Now i’m getting connection errors
Config entry:
Error Log: https://hastebin.com/rufevevayi.sql
@knackrack615
Change the url to:
url: amazon.com
Your logs are complaining the domain isn’t resolving and urllib is giving connection pool errors. You may need to reboot.
@auditdata
Change yours to.:
url: amazon.co.uk
Still no joy with url: amazon.co.uk.
This is the log? Any clues
2019-01-13 08:36:30 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.alexa which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-01-13 08:40:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.mr_s_fire_tv_stick is taking over 10 seconds
2019-01-13 08:40:35 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-13 08:42:13 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.kitchen_sonos is taking over 10 seconds
2019-01-13 08:42:14 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-13 08:44:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.kitchen_sonos is taking over 10 seconds
2019-01-13 08:47:41 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.mr_s_fire_tv_stick is taking over 10 seconds
2019-01-13 08:48:36 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.this_device is taking over 10 seconds
2019-01-13 08:48:36 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-13 08:49:19 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.clive_s_echo_spot is taking over 10 seconds
2019-01-13 08:49:19 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
2019-01-13 08:52:01 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.mr_s_reverb_ai is taking over 10 seconds
2019-01-13 08:52:02 WARNING (MainThread) [homeassistant.components.media_player] Updating alexa media_player took longer than the scheduled update interval 0:00:10
I use amazon japan and have no issues…works perfectly. My yaml:
media_player:
- platform: alexa
email: !secret alexa_un
password: !secret alexa_pw
url: amazon.co.jp
It seems to be just an issue of time. When I went to check that there were definately no media players in the current entities, low and behold they are now there. All 5 of my Amazon Alexa devices! Sweet. Now to try Text to speech…
My config for interest.
media_player:
- platform: alexa
email: !secret amazon_login
password: !secret amazon_password
url: "amazon.co.uk"
Thanks for all your help. Time seems to have fixed it!
After update to 0.85 I am getting this error (same error showed by @knackrack615 )
> Log Details (ERROR)
Sun Jan 13 2019 15:48:59 GMT+0100 (CET)
Error while setting up platform alexa
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/media_player/alexa.py”, line 142, in setup_platform
config.get(CONF_DEBUG))
File “/config/custom_components/media_player/alexa.py”, line 608, in init
self.login_with_cookie()
File “/config/custom_components/media_player/alexa.py”, line 631, in login_with_cookie
self.login(cookies=cookies)
File “/config/custom_components/media_player/alexa.py”, line 766, in login
self._data = self.get_inputs(soup)
File “/config/custom_components/media_player/alexa.py”, line 644, in get_inputs
for field in form.find_all(‘input’):
AttributeError: ‘NoneType’ object has no attribute ‘find_all’
Still problem for me. I tried remove media_player folder and download again alexa.py but promp for cookies doesn’t show up!
Hello, after changing my URL to amazon.com as suggested by @alandtse i’m now getting the following
requests.exceptions.MissingSchema: Invalid URL '': No schema supplied. Perhaps you meant http://?
