emulated hue is a bit easier but much more limited in functionality. Also, you may need a gen 1 or gen 2 echo dot (I can’t confirm that because I don’t have a gen 3, it’s just a rumor I’ve heard on the forums).
Yeah Hue is not an option, I thought once about it and checked it out but it looks like even if I wanted it needs port 80 and as said I’m behind a reverse-proxy.
Oh looks like I need this then? You’re also using the Alexa Smart Home Skill which I linked? And this is just a bridge then in another docker container?
I set up haaska recently and was bashing my head against a wall for a while trying to get it up and running - same symptoms as you - in the end I figured out amazon was rejecting my letsencrypt certificate no matter what combination of settings i tried so i moved everything in front of cloudflare (which is an awesome thing to do anyway because it gives you all kinds of other benefits)
i have been using haaska with a letsencrypt certificate for months again was a bit of a mare to set up but works great for me once done. just because i’m to cheap to pay for the homeassistant cloud though
So I have worked through steps 1-4 while I mostly was able to reuse what I had from the other guide, just totally different data. However part 4 “testing” worked altough that part already worked for the other way also.
Now I was able to activate the skill and link accounts. But when it asks me to search for devices it finds 0. Anything I missed? How do I use it from here?
EDIT: Ok now back on Home screen it tells me it found 6 devices. But that ain’t all I need. How can I proceed from here?
That sounds good, but in my case it ain’t lamps that are missing. It detects all Lights and Switches.
I just want it also to turn on/off the TV, Nvidia Shield, FireTV. Maybe even start the Xiaomi Roborock. And even more awesome would be to ask "Alexa, what is the living room temperature? Alexa, how is the air condition? And generally asking for sensor data…
Additionally to that I have to find out how it would automatically pause Automations then.
expose what you want from the vacuum as sensor, switch, or light templates. Not every domain is available for all components, so you have to finagle it over.
its possible that some sensor domains are not compatible. If hasska doesn’t have canned responses for a specific sensor type, chances are, it’ll ignore it.
