Hello everyone. I have a Ecobee 3 t stat and want to use " hvac_action:heating" and humidity level(like humidity <=40 %) to turn my sonoff switch( whole house humidifier) On and Off. My Ecobee entitie is climate_upstairs
Basically I want my humidifier start working only when my heater is Running and Humidity less or equal 40%
Thank you
Try the following automation. You will need to change the following entity names to match whatever you are using:
- climate.upstairs
- sensor.humidity
- switch.humidifier
- alias: Humidifier Controller
value_template: >
{{ is_state_attr('climate.upstairs', 'hvac_action', 'heating') and
states('sensor.humidity')|float <= 40 }}
value_template: "{{ not is_state_attr('climate.upstairs', 'hvac_action', 'heating') }}"
- service: "switch.turn_{{'on' if trigger.to_state.attributes.hvac_action == 'heating' else 'off' }}"
entity_id: switch.humidifier
Thank you,Taras
I will try tonight
The example I posted was designed to be copied and pasted into your automations.yaml
file.
You are trying to paste it into the Automation Editor but it’s not in the correct format for that. Change it to this:
value_template: >
Good morning
I thought if I switch to Yaml in Automation it’s the same like a automation .yaml
I am not really good in stuff like that , will try
Thank you
Fix my mistakes in automation .Yaml and looks like it’s working fine
Will test again tonight when come home, don’t want to scare my wife turning Heater on and Off remotely
Thanks again
It’s not exactly the same. The Automation Editor displays one automation’s YAML code in isolation from all other automations. Multiple automations, like when you look in automations.yaml
, have a slightly different appearance.
The following example is fine for a single automation (like when Automation Editor shows you the code for a single automation):
alias: example 1
- platform: state
entity_id: light.something1
- service: notify.notify
message: Hello from example 1.
However, when there are multiple automations, they are formatted like this (and you can confirm that by examining automations.yaml
- alias: example 1
- platform: state
- alias: example 2
- platform: state
entity_id: light.something2
message: Hello from example 2.
Let me know the results of your tests this evening.
Definitely will.
But so fur it’s seems to work fine
Heater is running, humidity is 38% and Humidifier switch kicked in
Glad to hear it works.
Please consider marking my first post (or second post) with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution. It also places a link beneath your first post that leads to the post containing the solution. All of this helps users find answers to similar questions.
I did it
Do you want to join us at MEWE for Home assistant group?
I appreciate the invitation but this forum already keeps me busy.
Good afternoon Taras
Everything is working like a charm
Thank you again
