I just upgraded to 107.5 and now the Ecobee thermostat is not working.
This is on the log. I have confirmed that the API is correct. Not sure what else to try.
Log Details (ERROR)
Logger: homeassistant.config_entries
Source: components/ecobee/__init__.py:105
First occurred: 10:19:19 PM (1 occurrences)
Last logged: 10:19:19 PM
Error setting up entry ecobee for ecobee
File "/usr/local/lib/python3.7/site-packages/pyecobee/__init__.py", line 513, in _request
response.raise_for_status()
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 941, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://api.ecobee.com/token?grant_type=refresh_token&refresh_token=XXXX&client_id=XXXX
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 216, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/ecobee/__init__.py", line 58, in async_setup_entry
if not await data.refresh():
File "/usr/src/homeassistant/homeassistant/components/ecobee/__init__.py", line 105, in refresh
if await self._hass.async_add_executor_job(self.ecobee.refresh_tokens):
File "/usr/local/lib/python3.7/site-packages/pyecobee/__init__.py", line 148, in refresh_tokens
auth_request=True,
File "/usr/local/lib/python3.7/site-packages/pyecobee/__init__.py", line 522, in _request
"ecobee tokens invalid; re-authentication required"
pyecobee.errors.InvalidTokenError: ecobee tokens invalid; re-authentication required
