I want to control fan_min_on_time in home assistant for an Ecobee thermostat. I can control the fan min on time in Ecobee app, but not through HomeKit integration. I am playing with the template:
Yes the HomeKit Device integration for Ecobee is good, but also leaves me wanting.
The ability to control the fan is in the HomeKit Device Integration, but it’s buried and not exposed as an entity. I created a script to access it. You need to get the actual device ID to get it to work. I’ve changed mine to <32 character device ID> for this example
hvac_exhaust_boost:
alias: "HVAC – Exhaust Boost (20 min)"
mode: restart
sequence:
# Turn HVAC fan ON for exhaust ventilation
- service: climate.set_fan_mode
device_id: <32 character device ID>
fan_mode: "on"
# Run for 20 minutes
- delay: "00:20:00"
# Check if PM2.5 filtration is currently active
# Only return to AUTO if air quality filtration is NOT running
# This prevents interference with PM2.5 air cleaning cycles
- condition: state
entity_id: input_boolean.pm25_filtration_active
state: "off"
# Return fan to AUTO mode (only if PM2.5 filtration is inactive)
fan_mode: "auto"
An easy way to get the device ID is to open the ecobee under HomeKit devices and services on the web. The 32 character string at the end of the URL will be your device ID for this script.
I didn’t have luck with using the entity id and getting the fan to respond, but also I didn’t spend more time on it once I got the above example working. That would be simple if the ecobee will respond to it.
