I’m trying to create an automation that has a condition that the ecobee must be in “cool” mode. I can’t find the appropriate climate.thermostat attribute. I’ve tried both “mode” and “hvac mode” as attributes and neither work nor are they listed as attributes under the Developer States page.
I see that hvac_action indicates what the system IS CURRENTLY doing (see heating below), but that’s no help when the system is idle.
I came across this old post… I have a similar issue with capturing the state of my ecobee. When the TSTAT is off (i.e. not heat, cool, or auto), then the circulation fan should be set to 0 min/hr. The latter part works fine, but the trigger does not.
What am I missing here? TIA!
