Ecobee input select automation Help
Hello, I am new to this and don’t fully understand, been stuck on this automation for a few days… Maybe someone can easily point out what I am doing wrong.
I am trying make a better interface for my ecobee, based on input selects and based on another thread I found. I am trying port over and swap out the ecobee’s syntax. So far, I did figure out how to extract the right attributes with value templates. For this example, I am just messing with setting the thermostat fan. The attribute is states.climate.my_ecobee3.attributes.fan. The automation works for changing input_select.hvac_fan_mode_downstairs, but not for states.climate.my_ecobee3.attributes.fan. I don’t understand how states.climate.my_ecobee3.attributes.fan gets changed?
automation.
Sets the downstairs thermostat fan_mode when the hvac_fan_mode input_select is changed
  • alias: ‘Set downstairs thermostat fan_mode based on input_select’
    platform: state
    entity_id: input_select.hvac_fan_mode_downstairs
    service: climate.set_fan_mode
    entity_id: climate.thermostat_downstairs_cooling_1_2_2
    data_template:
    fan_mode: >-
    {%- if is_state(‘input_select.hvac_fan_mode_downstairs’, ‘Off’) -%}
        {%- elif is_state('input_select.hvac_fan_mode_downstairs', 'On') -%}
            On
        {%- endif -%}
Sets the hvac_fan_mode input_select when the downstairs thermostat fan_mode is manually changed
  • alias: ‘Set input_select based on downstairs thermostat fan_mode’
    platform: state
    condition:
    condition: template
    value_template: ‘{{ trigger.to_states.climate.my_ecobee3.attributes.fan != trigger.from_states.climate.my_ecobee3.attributes.fan }}’
    service: input_select.select_option
    data_template:
    option: >-
    {% if states.climate.my_ecobee3.attributes.fan == ‘on’ %}
    on
    {%- elif states.climate.my_ecobee3.attributes.fan == ‘off’ %}
    Off
    {%- endif -%}
input select
hvac_fan_mode_downstairs:
options:
- ‘Auto’
- ‘On’
initial: Auto
icon: mdi:fan
I just looked into the ecobee code and I do not see any implementation there for climate.set_fan_mode. You probably can see some kind of error message in your log.
