Hey all,
I’ve been searching around on this issue, but haven’t seen any hits. When I try to integrate my ecobee thermostat into HA (2021.2.3), I get the following error after filling in the API key.
2021-02-28 20:34:40 ERROR (SyncWorker_0) [pyecobee] Error connecting to ecobee while attempting to request pin. Possible connectivity outage.
- I’ve deleted the Ecobee Application entry and created a new one a few times now.
- I spun up a brand new VM with a fresh HA image and still saw the same error.
- I tried a failing API key with the Ecobee developer example pages and saw a pin successfully created
So, I found the magic to turn on some additional logging, for ecobee and pyecobee, and got a little more detail out. This is all that I see in the logs around the time of the error.
2021-02-28 20:34:35 DEBUG (SyncWorker_0) [pyecobee] Making request to authorize endpoint to request pin: url: https://api.ecobee.com/authorize, headers: {}, params: {'response_type': 'ecobeePin', 'client_id': 'xxxxxxxxxxxx', 'scope': 'smartWrite'}, body: None
2021-02-28 20:34:40 DEBUG (SyncWorker_0) [pyecobee] Error obtaining PIN code from ecobee: 'NoneType' object is not subscriptable
Note: I scrubbed the real key out of the log message.
Has the format of the authorize request changed? I haven’t seen anything indicating that others are seeing this issue. Did I miss something?
Thanks!
Brent
