Has anyone been able to successfully use ecobee_resume_program? It shows up as an option on my services tab (and I’ve successfully used it there), and would be helpful in my automations. I tried setting up something like this:
- alias: Turn off away mode
platform: state
entity_id: group.residents
to: 'home'
condition:
condition: and
conditions:
- condition: time
after: '00:06:30'
- condition: time
before: '22:00:00'
service: ecobee_resume_program
entity_id: climate.main_floor
resume_all: true
But I keep getting this error:
17-02-28 23:57:01 ERROR (MainThread) [homeassistant.bootstrap] Invalid config for [automation]: Service ecobee_resume_program does not match format <domain>.<name> for dictionary value @ data['action'][0]['service']. Got None
extra keys not allowed @ data['action'][0]['resume_all']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 59). Please check the docs at https://home-assistant.io/components/automation/
It may just be the way you’re trying to call the action ecobee_resume_program
Try formatting it this way:
action[quote=“Kevin_Patrick, post:2, topic:12903, full:true”]
service: climate.ecobee_resume_program
resume_all: ‘true’
I’m new to this forum (and to HA in general) so my apologies for not knowing how to reply with formatted text. There should be indentation before ‘- service’ and ‘data’ and double indentation before ‘resume_all’
This is an old thread but… this is still an issue and Ecobee somtimes bounces and resumes and then goes to a custome state again. Calling it again usually works, though sometimes it would take a few tries. Since the repeat function in 0.113 I was able to use an input boolean and a repeat function to keep calling the comand every second until it had settled for 30 seconds on the correct value. Here is my code for the script to set resume all programs. You could alter it to fix the same problem in climate.set_preset_mode
